AOC led monitor
  • rigeback
    • Mar 2011
    • 421
    • Malta
    AOC led monitor
    Hey Guys, I have problem with a power supply board which I think is not starting up since there is no 5V.
    The board has a PWM Controller LD7576AGR (IC901) and might be bad according another post although there is 105V on the photocoupler pins.
    I changed the caps in the high voltage zone hoping for a quick fix but this is more complicated and not sure where go from her.
    Any thoughts appreciated.
  • R_J
    • Jun 2012
    • 9578
    Re: AOC led monitor
    What voltage do you have ACROSS the main filter, C907? check R924, it should read 0.47Ω.
    What photocoupler are you talking about? U902? if that is it, what ground were you using? hot ground or cold ground.
    • rigeback
      • Mar 2011
      • 421
      • Malta
      Re: AOC led monitor
      Yep I thought it was strange when I tested the big cap again and found I had 0 Volts, thought my multimeter was messed up.
      After seeing I wasn't getting 220V on board I tested the cable and low and behold the fuse was blown, not sure when or how this happened maybe before I changed the caps!
      To sum it up I replaced the fuse and every thing works. monitor is up and running.
      Thanks for refreshing my memory.
      Cheers
      • rigeback
        • Mar 2011
        • 421
        • Malta
        Re: AOC led monitor
        New problem with this monitor regarding the panel.
        It has developed a flickering to lines on the R/H side, I have tried adjusting it with display properties which helped a bit but I can see that it could be the panel at fault.
        I am considering the ribbon shim trick although it will be a complete tear down of the panel.
        Any thoughts suggestions??
        • rigeback
          • Mar 2011
          • 421
          • Malta
          Re: AOC led monitor
          Tried the ribbon shim trick but the problem does not seem to be with connectors and I'm thinking there could be some thing wrong with the T-Con?
          anyone had this issue before/
          Much appreciated any thoughts
          • nomoresonys
            • 12212
            • U.S.
            Re: AOC led monitor
            Full model number?
            • rigeback
              • Mar 2011
              • 421
              • Malta
              Re: AOC led monitor
              Hi there,
              Its the led AOC 19" e950SWda the service manual is attached with the first post.
              Most of the panel is good al; though with a quarter missing its a bummer
                by momaka
                03-15-2023, 10:17 PM
              • wattage
                by wattage
                Hello Badcaps Community,
                07-13-2025, 04:41 PM
              • ant3202
                HP 27es - LED monitor - Monitor Flashing On - Off
                by ant3202
                Hi Everyone
                Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                https://www.badcaps.net/forum/troubl...lashing-on-off
                The monitor is HP 27es LED Monitor
                https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                The monitor will randomly blackout and display no signal and will recover again.
                Sometimes need to power and off again to restore the display but...
                03-20-2025, 07:30 PM
              • Rick_1234
                by Rick_1234
                Good evening, gentlemen.
                Things I tried
                06-22-2024, 04:44 PM
                Wise Wing F199 19'' LCD monitor - recapped
                by momaka
                Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                When I saw the Craigslist post, I wasn't...
                08-24-2020, 10:58 AM
