SSL400_OE2D REV0.0 technical details ( Philips 40PFL4707)
  • genuineguy
    • Sep 2015
    • 46
    • india
    Hello
    My philips 40PFL4707/F7 has a LED driver board SSL400_OE2
    I am looking for technical details / data sheet or any information. Nothing available on google.
    If some one has at least the pinout voltages for its connectors CN1, CN2, CN3 kindly share.
  • genuineguy
    • Sep 2015
    • 46
    • india
    Re: SSL400_OE2D REV0.0 technical details ( Philips 40PFL4707)
    Found from another thread on bad caps that this board also has part # LJ97-00229A in some other TV models.
    • aidanmo
      Philips 43PUS7506/12 - Loud blown out sound
      by aidanmo
      I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
      I thought maybe the speakers got damaged, so I replaced them - no dice.
      • Using the internal speakers, it always happens.
      • Using the headphone jack, it never happens.
      • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
      02-28-2025, 03:13 PM
    • Cornito
      Philips 50PUH6400 bad color and gosting / slow motion on one side
      by Cornito
      Hello Team,
      New issue on LCD panel where I need to find out the cause and the potential solution.
      This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
      I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
      When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
      I've checked voltages, no issue found comparing right and left side of the panel driver.
      VHG VGL CKV... are the sames on...
      03-08-2024, 06:41 AM
    • spantor
      Activate power board Philips 40PFH40009/88 tv
      by spantor
      Hello partners.
      Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
      The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
      02-11-2024, 05:07 PM
    • lanada
      philips 55pus7909/12
      by lanada
      i have a philips for repair 55pus7909/12
      fault is no display but the white logo philips lit below of the screen
      No display
      No backlight
      no sound
      power supply the standby voltages are ok
      Any Help regarding this problem?
      11-07-2023, 02:31 AM
    • betmen
      TV Philips 40PFT4101/12 - power on loop
      by betmen
      TV is Philips 40PFT4101/12, power supply 715G6934-P01-000-002M, motherboard 715G6947-M002-000-004Y (703TQGPL068).
      The problem is that when it is plugged in, the TV turns on by itself, the Philips sign appears, the backlight turns on and off a couple of times, and the TV turns off, and so it repeats itself in a circle. It does not respond to the remote and nothing is written on the screen, the red light does not blink.
      A few weeks ago, it used to turn on by itself about once a week, but after that it worked, now it doesn't work.
      I checked the power supply, voltages are fine,...
      11-05-2023, 05:45 AM
