Sharp LC-60LE650U
  • electrobe
    • Sep 2012
    • 70
    • usa
    Sharp LC-60LE650U
    I have a Sharp LC-60LE650U that shuts on and off with only Sharp logo displaying before it goes off then repeats. When the tv is powered on the standby light is blinks once then goes off for a count of 2 then then repeats same. I could use a schematic for this model if available.
  • electrobe
    • Sep 2012
    • 70
    • usa
    Re: Sharp LC-60LE650U
    Hello I wanted to check to see if any of you may have a schematic for this Sharp model tv
    • nomoresonys
      • 12206
      • U.S.
      More than likely a probem with eeprom/spi/nand on the mainboard, easiest fix is a replacement mainboard if that is the problem.
        1) There is not much info in the service manual. https://www.manualslib.com/manual/11...-60le650u.html
        2) I have error codes for 640 so it may be closed enough, see attached PDF. ou should re-verify the blink code again Example of error code: https://www.youtube.com/watch?v=jHjBjIaQzXc
        3) Show us good clear pictures of the whole backside of the TV showing all the boards, the good clear straight shots of the whole power supply board.
        4) What Voltage testing have you done on the power supply connector that goes to the main board?
        • advant
          by advant
          02-03-2020, 12:25 AM
        • sefoster
          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
          by sefoster
          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
          11-20-2022, 09:29 AM
        • gavenb
          Sharp LC-80LE661U 80 inch
          by gavenb
          Hi folks!
          I have a LC-80LE661U that had some interesting issues.
          Initially, it would come on and show the sharp logo and would show normal static before shutting off.
          I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
          11-12-2023, 02:05 PM
        • SONY_E-WASTER
          Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
          by SONY_E-WASTER
          Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
          The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
          then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
          does...
          12-26-2021, 05:46 PM
        • betmen
          TV Sharp LC-49CFE6242E - not working
          by betmen
          I get one old TV, Sharp LC-49CFE6242E which is not working.
          When turning on the TV, the inscription SHARP is displayed on the screen and after a few seconds the TV turns off.
          So far I haven't found what voltages should be at the output of the power supply and I haven't made any measurements.
          If anyone has any ideas, please let me know.​
          Starts
          10-19-2024
          Ends
          11-19-2024
          10-20-2024, 08:44 AM
