55 inch vestel linsar with half line on the screen
  • adamp91gvm
    • Jan 2014
    • 706
    Hi does anyone know how to fix this or had this before I have checked tabs changed ribbons but still no different
  • adamp91gvm
    • Jan 2014
    • 706
    Re: 55 inch vestel linsar with half line on the screen
    Sorry this is the pic
    • Diah
      • Feb 2013
      • 6614
      which model No.?
      can you finish the first installation after you reset it from service menu ( Not from setting menu ) and play signal feed to show us photo of the issue..! did you clean LVDS too?
      • adamp91gvm
        • Jan 2014
        • 706
        It's a 55hdr510
        • adamp91gvm
          • Jan 2014
          • 706
          Yes cleaned the Lvds too
          • Diah
            • Feb 2013
            • 6614
            the line at the 3/4 right side correct?
            if you remove one ribbon on the effected side... did you got clear white screen or there also the line.. also you have on the effected side at the panel lower boards U ribbon cable did you check it... and what it will show if you disconnected it ?
            • adamp91gvm
              • Jan 2014
              • 706
              It's a clear white screen if its disconnected Al's checked the connection ribbon between the two boards
              • Diah
                • Feb 2013
                • 6614
                dead pixel.
                • adamp91gvm
                  • Jan 2014
                  • 706
                  Any CPR I can give it ha ha
                  • Diah
                    • Feb 2013
                    • 6614
                    yes... but before you need to take MRT
                    focused x10 your camera on the line to see how they are dead LOL
                    • adamp91gvm
                      • Jan 2014
                      • 706
                      Looks like 1 dead
                      • Chrissygizmo
                        by Chrissygizmo
                        02-10-2025, 12:33 AM
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • valvashon
                        LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                        by valvashon
                        The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                        Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                        11-24-2024, 12:08 PM
                      • Raulnn
                        TD Systems K50DLG12US half black and half white screen
                        by Raulnn
                        good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                        By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                        01-20-2024, 04:49 PM
