M43-C1 1 long blink 16 short
  • Techboxcomputer
    • Aug 2016
    • 61
    Hi all -
    I have been playing around with TV repair for a while now but computer repair is my 20 year thing. Regardless. Voltage measurements and things relative to that I am just starting to learn, very rookie. My victim is the M43-C1 as shown above with it's blink code. Original complaint was only half screen so I want with a roll of the dice and bought a control board, no dice. Today I was experimenting with checking voltages and trying to educate myself slowly. I had given up on the power board as I thought I had understood the voltages and the checked out. So I watched a video and tried some other checks. Touching one pin lit up every single LED completely by accident. I will post pictures below. I think I have it now narrowed down to the driver board or the main, but I will listen. I have worked on several of these Visio's and the main has burned out in them, but as I have said, I am learning.
    TIA
  • Techboxcomputer
    • Aug 2016
    • 61
    Re: M43-C1 1 long blink 16 short
    Pictures for the thread.
    • neilc6
      • Nov 2015
      • 1550
      This TV doesnt have blink codes. Likely a bad main board. I have purchased used ones with the same failure.
      https://www.badcaps.net/forum/showthread.php?t=76708
      • Techboxcomputer
        • Aug 2016
        • 61
        I'm still interest to know why when I touched my fluke on the pin on the main I have in the picture below I lit up every LED and how that rules out the driver board.
        • Techboxcomputer
          • Aug 2016
          • 61
          Update:
          I sent this main board out for repair. The TV now will now power up the backlights with the power button every time but no display (Visio icon or image on boot) and I still get a blinking power light.
          • Nick's Tvs
            • Jan 2014
            • 621
            if the main board was sent out for repair, then the repair company must have confirmed the issue prior to performing repairs and confirmed the failure to be resolved post repair is that correct?
            If that is the case, then your board should be fully functional unless 1 of three things happend.
            1) The LVDS ribbon connecting the main board to the T-con is not seated properly.
            2) The main board is still defective.
            3) Extremely unlikely but your screen or T-con is bad. I honestly wouldn't even consider this option unless you think you accidentaly damaged them.
            • Techboxcomputer
              • Aug 2016
              • 61
              To put closure to this thread. The main board was repaired and that was the initial problem. When I had it returned to me I did not seat it properly (as stated above) which is why it would not come up. I pulled it from both the inverter and the main, reseated and voila all was well.
              • szreder6
                HP Pavilion 14-ce0505sa, 5 long 3 short, no display. g7a-2g da0g7ambd1
                by szreder6
                Hello guys,
                I have a problem with my laptop as in the title, black screen, capslock displays error code 5 long 3 short, no voltage on the coils above the CPU, before removing the drive I had 0.8v there, power led flashed 5x long and the battery would not charge (current jumped from 0.5a to 2.8a), now on the power led I have a steady white light or orange when the battery is connected.
                What I did:
                - Laptop was not detecting ram, loose pins on ram slot, error 3.2 disappeared, ram working tested in another laptop
                As far as I know the laptop was in another service center...
                11-22-2024, 05:17 PM
              • Rotorcraft230
                Sharp LC 80C6500U 1 long 1 short blink
                by Rotorcraft230
                Hello all, I have been here from time to time and now I'm back for some assistance.
                So I have the TV above and its doing the one long and one short "V" blinking. I did the reset on the controls on the side of the TV and while holding down the volume - and the input button, then plugging in the TV the "V" light is solid, then very briefly I see the backlight flash, then the "V" goes back to the 1 long and 1 short blinking. I just want to make sure its the backlights before I get the parts to fix it. Is there anything else I can do to confirm its the lights....
                02-28-2021, 04:14 PM
              • jm942
                Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                by jm942
                My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                I did voltage injection on the cpu with 0.7V and i have a current...
                07-11-2024, 05:11 AM
              • Aziz aj
                caps lock 5 long 3 short black screen
                by Aziz aj
                rev-1.0
                input short remove then caps lock 5 long 3 short no output how to solve this problem
                06-08-2024, 07:47 AM
              • lapfix
                Hp 15 capslock 5 long 3 short pb.
                by lapfix
                Hello friends.
                hp 15 -da009nk ...la-g07cp.
                got this lap with capslock 5 long 3 short.
                Try new dump f.48 still the same.
                try another dump f.04 power on..no display..consumption 0.498..no caps lock blinking.
                ​​​​all voltage are présent.
                pl301/302= 3 and 5 volt.
                pl1001 1.082v.
                pla1 1.033v
                plz1 vcc core 1.058v
                plg1 0v..i think it s the Intel grpahic
                plw1 1.373v.
                plv 3/plv4 vga core 0.918v
                consumption 0.498.
                original bios version f.02..
                any help!...
                02-18-2025, 03:34 AM
