50PA6500-UA Power board relay going insane!
  • Jeryswan
    • Mar 2020
    • 39
    I have a plasma TV model # 50PA6500-UA that when the customer plugs it in, the screen flashes on and off and you can hear a relay on the power supply board continuously clicks on and off. I replaced the relay but the problem persisted. After further testing, I noticed that when the main board is disconnected from the power supply board the problem doesn't occur. Any tests or advice that could lead me to a conclusive board that I should replace would be very much appreciated.
  • Jeryswan
    • Mar 2020
    • 39
    Re: Power board relay going insane!
    This is the relay we replaced
    • Jeryswan
      • Mar 2020
      • 39
      here's a couple more pictures.
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        the relay is doing whats its told . now you have to find why its behaving so . does the relay click once with main board removed ?
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          Unplug the tv. Unplug the ldvs ribbon from the mainboard to the control board and put a piece of wire in the holes marked auto ext on the control board. Plug the tv back in and check if you have test patterns on the screen.
          • chrismurphy
            • May 2014
            • 251
            • australia
            a long shot replace the blue cap in the middle next to the large transformer
            • Jeryswan
              • Mar 2020
              • 39
              Yes it does click the once. it does not continue to click.
              • Jeryswan
                • Mar 2020
                • 39
                We did the above test and got nothing. It wasn't until we unplugged the main board from the power supply with the rest of the test parameters that the test patterns started. Is it possible that the main board it telling the power supply to turn on and off repeatedly?
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  If the tv stays on and goes through the test patterns the mainboard is bad (BGA chip).
                  • Jeryswan
                    • Mar 2020
                    • 39
                    Thanks homie. I appreciate ya.
                    • Jeryswan
                      • Mar 2020
                      • 39
                      Bought a new main logic and control board. no help. what's next.
                      • jjanssen7
                        • Nov 2012
                        • 252
                        Do post #6. They had a lot of bad blue caps at that location. fixed a few PA series with that problem back in 2015...
                        See https://www.badcaps.net/forum/showth...t=38197&page=3
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                          by sam_sam_sam
                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                          Found shorted diodes on main controller relays there are 3 of them that...
                          01-07-2023, 05:43 PM
                        • valvashon
                          Repair Success! Middle Atlantic UPS2200R-IP
                          by valvashon
                          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                          02-06-2024, 12:54 PM
                        • jb_Bak
                          by jb_Bak
                          CN6401
                          Pin 01 NC
                          Pin 02 NC
                          Pin 03 "BL_ON": 0V
                          Pin 04 "N/C"
                          Pin 05 "STBY 3.3V": 3.5V
                          Pin 06 "GND": N/C
                          Pin 07 "AC_OFF"...
                          09-27-2021, 04:52 PM
