Philips 42PFL4606 No Backlight
  • trunks81
    • May 2020
    • 265
    • Nederland
    Hello Guys
    This time ive got an 4606 again but with totally different issue
    When powering on the unit you see the logo for an few second and after that only with an flashlight, ive tested the tv with an 47 SMPS and the all is working fine, So problem must be located in the 42 SMPS.
    When measuring ENA and DIM i get 4,9V and 2,6V this while the tv is powered on.
    Also between PIN 17 and 22 iam getting an High ohm reading 83K.
    Which section do i need to check ?
  • trunks81
    • May 2020
    • 265
    • Nederland
    Re: Philips 42PFL4606 No Backlight
    Changed IC801 (UBA2071AT) no difference
    • trunks81
      • May 2020
      • 265
      • Nederland
      Iam getting the 395V on the inverter side
        Does the VDD on pin 16 of IC801 stay present after the backlights cut off?
        The 395VDC PFC Boost Voltage also stay when the backlights cut off?
        • trunks81
          • May 2020
          • 265
          • Nederland
          hello Budm,
          the pfc 395v is present even when BL cut off,
          on pin 16 ive an stable 12v
            Check the resistance of the two high Voltage windings (PIN 5 & 6, 7 & 8) of the inverter transformer T803 and also compare it to the working board.
            • trunks81
              • May 2020
              • 265
              • Nederland
              Hello Budm
              Both boards measure an 12ohm between pin 5&6 and 7&8
              • trunks81
                • May 2020
                • 265
                • Nederland
                Hi i did some very intensive research i measured all resistors in the Inverter part.
                Where needed i desoldered them of the board to measure.
                iam not sure how to measure the ceramic capacitors ? any ideas how to do that on a good manor
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  I would have thought that R801 and R892 resistance to be identical.
                  Have you check C802. These high voltage capacitors in series with transformers do tend to fail.
                  • trunks81
                    • May 2020
                    • 265
                    • Nederland
                    Hello
                    C802 is checking out oke, Desoldered it an did an measurement it reading 330nf
                    Did you mean R829 ? and R801
                    • trunks81
                      • May 2020
                      • 265
                      • Nederland
                      which section does the checking for the inverter
                      • trunks81
                        • May 2020
                        • 265
                        • Nederland
                        Who has an idea ? with the spare board the tv is running! So CCFL tubes should be fine
                          What is the Voltage on EN pin 15?
                          • trunks81
                            • May 2020
                            • 265
                            • Nederland
                            Ive got 5.8V on EN pin 15
                            • trunks81
                              • May 2020
                              • 265
                              • Nederland
                              What does that voltage mean ? while measering on the other board i accendently made an short so for now i can not use tjat board
                                That means the Backlights on command is still present on the EN pin but the IC is in protection mode some how.
                                • trunks81
                                  • May 2020
                                  • 265
                                  • Nederland
                                  mmh difficult now i need to find out why
                                  • chestercc
                                    Philips TV Backlight Repair
                                    by chestercc
                                    So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
                                    My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
                                    The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
                                    11-18-2022, 01:15 PM
                                  • ohren
                                    Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
                                    by ohren
                                    I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
                                    The setup is basically:
                                    Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
                                    Transistor is switching the 3.5 V supply on the power board....
                                    12-05-2024, 11:10 AM
                                  • triplefour
                                    by triplefour
                                    09-13-2023, 10:43 PM
                                  • ovrax
                                    Philips 55PUS6804/12 turn on & off (probably backlight issue)
                                    by ovrax
                                    First of all, please excuse me as I'm quite new to this field.
                                    I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                                    I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                                    The Ambilight works perfectly and stays on.
                                    No sounds.
                                    Thanks in advance.
                                    08-25-2024, 04:33 AM
                                  • DoOm86
                                    philips 55pft5500/12 Backlight issue. What am I doing wrong?
                                    by DoOm86
                                    TV philips 55'' no backlight (image ok).
                                    I tested the backlight with my led tester from the unplugged connector cable and it lights up. I had voltages at the motherboard connector, but anyway I order a new psu. Same problem, same voltages. Disassembled the TV and checked every strip with my led tester, they all light up, same voltage for every pair of strip (they go two by two).
                                    What am I missing?
                                    And something else I don't understand. I checked and I have 3v Leds, 10 per strips. Why every pair of strip (so 20 Led) take about 32v when powered up with my led tester 🤔
                                    04-16-2024, 03:47 PM
