Vizio 65”
  • BradHowett
    • Oct 2020
    Vizio 65”
    Hi everyone. My first thread here. I hope you guys can help.
    I have a 65” Vizio. e650i-b2.
    I got the TV for $40 yesterday because i feel like I can fix it.
    Here's what happens: I turn the TV on. White lite in the bottom left corner comes on. The backlights come on for the blank black screen. As soon as the logo comes on the back lights turn off and the white power light dims and the TV powers off. It is not the back lights. I am on the verge of replacing the power board or main board and have them both in my shopping cart. I need to know which you all think the most likely is to have failed so I can order that part. I think it is the main board but my knowledge is limited.
    Re: Vizio 65”
    Please use GO ADVANCED to attach the pictures of the whole backside of the TV showing all the boards so we can see what we are dealing with.
    What Voltage testing have you done?
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • SS454
      vizio e650i-a2 backlight flashes then turns off
      by SS454
      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
      panel: au optronics T650HVN05.4
      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
      https://www.shopjimmy.com/vizio-56-0...-power-supply/
      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
      08-20-2020, 03:57 PM
    • mrtek
      Vizio M65-C1
      by mrtek
      Hi.
      picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
      When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
      This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
      07-14-2025, 07:28 PM
    • howardc64
      Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
      by howardc64
      Failure Symptom
      No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
      Where is the short?
      Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
      Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
      05-27-2025, 02:56 PM
    • howardc64
      Vizio SmartCast TV software bug that looks like hardware
      by howardc64
      Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
      It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
      11-16-2024, 05:17 PM
