Vizio E701i
  • Hornnumb2
    • Feb 2011
    • 218
    Vizio E701i
    Would I be stupid to purchase a non working one of these? I have been reading through the hack thread on it. What should I offer or not?
  • nomoresonys
    • 12274
    • U.S.
    Re: Vizio E701i
    Probably not much, they are getting pretty old by now. Ran across this: https://hdguru.com/vizio-issues-a-re...led-lcd-hdtvs/
    • otaku_nut
      Vizio E701i-A3 fixed but now has red vertical line
      by otaku_nut
      Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
      08-19-2025, 06:11 PM
    • Super360
      Vizio E701i-A3 Vizio logo flashing then turns off
      by Super360
      Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
      07-25-2024, 07:06 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • Awsmessymail
      Vizio E701i-A3 backlight only and now no backlight
      by Awsmessymail
      Hello all,
      I’ve tried to repair TVs in the past with some luck. Toms repair manuals got taken down and now thats a bit harder.
      I picked this TV up hoping for a quick fix. When the TV would power on, only the backlights would come on. The owner told me they heard loud screeching before it shut off. This alone makes me want to think the main board has an issue.
      As I researched, I found the TCON/driver boards were an issue on this unit. I went in troubleshooting the TCON but found good voltages on the TCON. I followed shop jimmys guide to test the transistors and they seem okay....
      02-13-2024, 11:04 PM
    • SS454
      vizio e650i-a2 backlight flashes then turns off
      by SS454
      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
      panel: au optronics T650HVN05.4
      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
      https://www.shopjimmy.com/vizio-56-0...-power-supply/
      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
      08-20-2020, 03:57 PM
