Maxent MX-27x1 LCD TV Screen On For Split Second Then Off
  • audiogroove
    Maxent MX-27x1 LCD TV when turned on it displays for a half second then screen goes off. Can still see computer output on screen with no backlighting. I took the whole TV apart and visually checked all the capacitors: none look damaged. While it was apart I found if I put pressure on opposing corners (longest dimension) the backlight would stay on until the pressure was released. After taking it completely apart and reassembling it wouldn't do that anymore. Back to only split second of backlighting when turning on or plugging/unplugging computer. When it is lit the lighting is bright and consistent. Any ideas? I should add that I'm very mechanically inclined and have done alot of soldering (have wired recording studios) but I am not an electronics tech.
  • electroguy75
    • Dec 2008
    • 21
    Re: Maxent MX-27x1 LCD TV Screen On For Split Second Then Off
    from ur description of flexing board, sounds as if u may have a bad solder joint causing ur problems.chk solder joints and reflow all that look suspect. pay particular attention to transformer joints.cheers
    • audiogroove
      Power Supply transformers or inverter board transformers?
      • electroguy75
        • Dec 2008
        • 21
        sorry, inverter board. cheers
        • audiogroove
          Anyone else have any ideas?
          • PlainBill
            • Feb 2009
            • 7034
            The symptoms indicate a problem in the backlight system. Specifically, it appears the backlight protection logic is shutting them down. Electorguy75's idea of a bad solder joint is plausible, but it could also be a wiring problem to a CCFL. The first step is to identify the failure mode.
            In cases like this, I suggest attaching good pictures of the inverter (top and bottom), including one with the CCFL leads plugged in.
            PlainBill
            • audiogroove
              PlainBill
              Thanks Plain Bill, I will post pictures as soon as I have time to disassemble the unit again.
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • smic717394
                by smic717394
                07-25-2024, 10:16 AM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • spice_disc
                Vizio TV M50-C1 reboot cycle and static on screen
                by spice_disc
                I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                09-08-2024, 02:37 PM
              • ipatch
                ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                by ipatch
                i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                08-24-2024, 02:36 PM
