Hisense 55'' Issues Mainboard or Power Supply?
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Re: Hisense 55'' Issues Mainboard or Power Supply?
    from my experience with todays junk made LED LCD tvs 95% of the time the issue with no backlight is a bad LED strip or strips
    • dabushar
      • Aug 2019
      • 23
      • Kenya
      Originally posted by Davi.p
      ok this is a good test, so with external strips its shuts off after how much time or in which condition?
      Immediately there is any load. Aerial, DTV, HDMI, Youtube. Anytype of load. But if you turn it off completely and start it again it just starts up normally. If there was a faulty strip am pretty sure it wouldnt go on because they are very sensitive.
      I have attached videos.
      • dabushar
        • Aug 2019
        • 23
        • Kenya
        Its a mainboard issue.. This particular mainboard has a connector which i think sends a signal for the backlights. My A6103 doesnt have that capabilty.. So i resolved to get a mainboard for the MEA region.
        • Diah
          • Feb 2013
          • 6376
          more exact its firmware issue on the main boards ( didn't match ) if you could find firmware for A6100 series you can force the set to write the new firmware..
          how!!... while the set working on unplug it from wall socket.. put the firmware on usb stick formatted with fat32 and insert it at USB Port V.2 not the blue one V.3
          press the power bottom on the RC and keep pressing while you plug it back to wall socket .. release the pressing when you see upgrading on the screen.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4333
            • Italy - Milan
            Have you resolved?
            • dabushar
              • Aug 2019
              • 23
              • Kenya
              #26
              Have you resolved?
              I dont want to burn this BL's because changing them is a hassle, a big hassle. I am looking for the firmware Diah suggessted and try upgrade or downgrade it while i wait for the Mainboard for the A6103 to arrive.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4333
                • Italy - Milan
                #27
                it was not clear...
                • Diah
                  • Feb 2013
                  • 6376
                  okay, i did found for you firmware for 55A6100..
                  you can use the methods i described before or first use this method hope it will success too
                  1. Format a USB flash disk as FAT32.
                  2. Copy the .bin file as-is onto the root of the USB flash disk (Do not rename the file, do not put the file into a folder)
                  3. Put your TV on, and go to Settings > Support > System Update > Upgrade from USB
                  4. The TV will automatically detect that a firmware upgrade file exists on the USB. Click Yes or Ok to continue.
                  5. Your TV will now reboot and install the firmware. (It might stay at 1% for a while. This is normal. The progress bar will eventually move. DO NOT power off your TV during the firmware update process)
                  6. Once the firmware installs, your TV will reset to its factory default state.
                  in case the set didnt reset it self after writing the new firmware... do it from service menu (Clean Chip ) and then from install menu factory reset.
                  • dabushar
                    • Aug 2019
                    • 23
                    • Kenya
                    #29
                    It doesnt recognize the usb upgrade package... I tried to hold the RC power button while booting to force it but it just starts up..
                    • Diah
                      • Feb 2013
                      • 6376
                      it sound you may have hidden file remain on your USB stick.... some windows system when you format they generate hidden file named "System Volume Information"
                      you need to enable at the pc to show hidden files.. and such file on the usb to delete it.
                      • dabushar
                        • Aug 2019
                        • 23
                        • Kenya
                        #31
                        It didn't work. I tried everything. I formatted and checked if the flash was empty, it was, I copoed the file. But the TV doesn't recognize the upgrade. I don't know if it's the chipset or something. But it's not working. It's refusing to flash the firmware
                        • Diah
                          • Feb 2013
                          • 6376
                          try this another firmware
                          • Diah
                            • Feb 2013
                            • 6376
                            you can trick the set to think its same model firmware.. by rename it as the model such usb_xxxxxxxx.bin
                            you can know the firmware of this boards and model better from service menu.. go to menu audio setting-advanced setting--- balance mark it at level 0 then press on RC 1969 letter M will show on the top left corner.. by pressing menu again will show you at first page. to exit just turn the set off to by RC
                            • dabushar
                              • Aug 2019
                              • 23
                              • Kenya
                              #34
                              I cleaned the usb booted to a clean usb os and formatted the usb and made sure it was empty, tried both firmwares( usb_xxxxxxxx.bin, usb_xxx.xxx.xx.bin and none worked.. i tried renaming the files as you suggested also failed.. both on settings and rebooting while holding power on rc.
                              I did however manage to get into the service menu... Took a pic.
                              • Diah
                                • Feb 2013
                                • 6376
                                if you renamed the FW as the current model as the replacement boards, you need to use the upgrade method i wrote at my post #28 !!
                                between it show yours now HU55A6106 !!!!! not as you told us H8000 ??? LOL
                                try now from service menu option clear all.. when the tv restart go to setting and make factory reset from there again.
                                • dabushar
                                  • Aug 2019
                                  • 23
                                  • Kenya
                                  #36
                                  HU55A6106 Is the new boards version. The original was A6103
                                  I realized that the option will not work as on the replacement board there is connector which sends a signal to an oscillator board on the power supply to control the backlights.. So the firmware won't work per say.
                                  The power supply board for this specific board has an extra board which i assume is a power oscillator.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4333
                                    • Italy - Milan
                                    #37
                                    Your main problem is not mainboard, check the V of the STB pin on psu, if is not over 5v place a jumper SW-STB , if yes place a diode and detach mainboard, leave it to stay and watch if BL comes off after a while, if yes you have bad strips. In alternative, let tv work normally and place voltmeter on SW pin , if when BL comes off the SW pin changes then you have wrong mabo otherwise bad leds.
                                      by sam_sam_sam
                                      03-31-2024, 02:12 PM
                                    • Jembang
                                      coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
                                      by Jembang
                                      good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
                                      11-01-2024, 09:55 AM
                                    • JimBanville
                                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                      by JimBanville
                                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                      09-13-2023, 07:21 AM
                                    • CMCM
                                      Russound CA4 Power Supply Repair
                                      by CMCM
                                      Hello Everybody,
                                      Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                      Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                      The outputs marked 12v and 20v are all measuring only 1v.
                                      The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                      The capacitors physically look clean (no bludgesor leaks) and...
                                      07-03-2025, 01:12 PM
