Philips 37pfl9632d/10 no image after main board replacment
  • Vasmane
    • Sep 2020
    • 9
    • Bulgaria
    Hi guys and thanks for accepting me in your community. Firstly I want to say that I've never done any repairs on TVs , but I have basic electronic knowledge. So the thing is that my tv main board failed and I've found the same board but from a 32” screen. Tv powers up now but I don't have image on screen (backlight is on) . The 32” board connects directly to the tcon board but mine connects to other and then the tcon. I'll post photos later. I'm not sure if this is a firmware problem or hardware. However , I can connect the one cable straight from mb to tcon and get distorted image so I can see what I'm doing. I'll post pics on the second post. Thank you
  • Vasmane
    • Sep 2020
    • 9
    • Bulgaria
    Re: Philips 37pfl9632d/10 no image after main board replacment
    First photo is the 37” screen that I want to repair and the second is the 32” donor
    • trunks81
      • May 2020
      • 265
      • Nederland
      possible that you need to enter the correct display code ?
      you can find that 3 digit code on the back,
      you can change the code by entering 062598 followed by the code, then the tv will turn of and the code is changed
      • Vasmane
        • Sep 2020
        • 9
        • Bulgaria
        Thank you. I've tried the code but now the backlight is constantly turning on and off. Probably not the one , I'm not sure 🤔
        • trunks81
          • May 2020
          • 265
          • Nederland
          display code is 114, van you see an image when BL is turning on and off
          • Vasmane
            • Sep 2020
            • 9
            • Bulgaria
            I've used 114 code no image when backlight is on. I can't turn it off as well
            • Vasmane
              • Sep 2020
              • 9
              • Bulgaria
              Also when ssb cable is disconnected it does not bootloop �� probably a faulty 3104 301 3034
              • Vasmane
                • Sep 2020
                • 9
                • Bulgaria
                Reflowed chip on 3104 301 3034 and now it works. Thanks for the advice , I wouldn’t do it on my own )
                • William1967
                  • Nov 2017
                  • 210
                  • Netherlands
                  Only 062598 followed by the code is not enough, you must use 062598-MENU-XXX where XXX is the 3 digit number you can find on the rear.
                  • Vasmane
                    • Sep 2020
                    • 9
                    • Bulgaria
                    Guys , I've bought another working dfi panel from 37pfl9732/10d , because my reball was unsuccessful and I can't make it work. I have found all the display diversity codes for that model and tried them all. When I disconnect the pcb lvds cable, tv boots , but when I connect it to the dfi ot goes into protection. Any advices? I can add the service manual if needed. Thanks in advance!
                    • Vasmane
                      • Sep 2020
                      • 9
                      • Bulgaria
                      Okay well then i guess it’s doomed
                      • tuner2000i
                        Philips 65PUS8518/12 distorted image after main board replacement
                        by tuner2000i
                        hello everyone,
                        I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                        The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                        07-15-2025, 01:15 PM
                      • Dani_2024
                        by Dani_2024
                        10-28-2024, 05:06 PM
                      • ygorsan
                        by ygorsan
                        🧩 Problem Summary:
                        • I
                        07-28-2025, 08:34 AM
                      • jb_Bak
                        by jb_Bak
                        CN6401
                        Pin 01 NC
                        Pin 02 NC
                        Pin 03 "BL_ON": 0V
                        Pin 04 "N/C"
                        Pin 05 "STBY 3.3V": 3.5V
                        Pin 06 "GND": N/C
                        Pin 07 "AC_OFF"...
                        09-27-2021, 04:52 PM
                      • JDC
                        (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                        by JDC
                        ONN 100012588
                        Issue: No Power, Then Rebooting After Main Board Change
                        Short answer: replace main board and power board
                        Technical answer: replace main board and Q306 & Q307 on power board.
                        Long answer:
                        TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                        07-15-2022, 07:39 AM
