TCL 55S403 No picture. Sound and Backlight OK.
  • Jeryswan
    • Mar 2020
    • 39
    To start, my electronics repair shop is pretty new to the TV repair game so forgive me asking noob questions. Plus I am fairly new to this forum so if this has already been answered, I may need some help using the search function more efficiently.
    I have a 55" 55S403 that turns on, produces sound and backlight but no picture. Tested voltages on the T-con and mainboard and voltage is present. Honestly, don't exactly know what voltages to look for but we know it at least has voltage present. No panel ribbons are torn. Reseated all connections between boards.
    It sounds like it might be in need of a T-CON replacement..... However, we are new and don't really know what we are doing.
    Yes, we are Youtube university specialists. Specialist is used VERY loosely. lol
    On a separate note, I would LOVE to send my tech to get some TV repair training. Anyone know anywhere good?
  • neilc6
    • Nov 2015
    • 1550
    Re: TCL 55S403 No picture. Sound and Backlight OK.
    With a TV turning on with backlight and no video, the first suspect is the tcon board. Some newer models don't have tcons. To make sure it's not the panel, power up the TV with only one ribbon between the tcon and panel connected at a time to see if one side displays a picture. If one side is good, it's a bad panel and not the tcon.
      Show us good clear pictures (using 'Go Advanced' to attach the pictures) of the whole backside of the TV showing all the boards so we can see what we are dealing with.
      • Jeryswan
        • Mar 2020
        • 39
        Here's some pictures of the back of the TV and all the boards. After we unplugged one side of the tcon, this is what the tv looked like. it was mirrored for when we tried the same thing with the other side.
        • Jeryswan
          • Mar 2020
          • 39
          Check out the pictures above.
          • Jeryswan
            • Mar 2020
            • 39
            Checked both sides by unplugging panel to tcon ribbon on left side only then on right side only. Neither side displayed an actual picture. Just black with one side white and vise versa for the other side. I posted a picture above with what it looks like.
            • budwich
              • Jul 2015
              • 3097
              your panel has a problem in the top right corner of the panel... the black "corner". Not sure if you can do anything about it on a TCL set as they are somewhat different than others because of a "roku based" operating system.
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • LaPCon_IT
                Samsung UE50TU7099U no picture no sound, backlight present
                by LaPCon_IT
                TV has one combo board (VTT55UH160). Symptoms are like this.
                When part of the screen is disconnected (white part), it looks like this
                Resistance and voltages (I don't know if they are good or not). The inductor with 0ohm/0V seems to be connected to GND.
                I haven't noticed any shorts on rails listed below:
                VGH - 30V
                VGL- -9V
                VAA - 14V
                VCOM - 5.6V
                STV - 11.95V
                LC1, LC2 - +30/-12V
                All CKV lines (no shorts between them) looks the same:
                I've tried to cover some lines with...
                12-15-2023, 03:55 AM
              • maneatingmonkey
                Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                by maneatingmonkey
                I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                03-27-2024, 07:17 AM
