Samsung HPR5072- No Power- No Standby
  • fixitjunkie
    • Feb 2014
    • 39
    Hello All,
    My Samsung 50" Plasma experienced a lightning induced voltage surge resulting in no power and no standby light condition.
    There is voltage going to the Power Supply board, but no AC voltage present at either test point Vs or Va.
    From what I've read, there's a 50-50 chance between the Power Supply PCB or Main PCB.
    There are some threads about unpluging ribbons and jumpering pins to determine if it's the main board but not sure if pertains to this model.
    I have some experience working on electronics but not with TV's.
    Any feedback would be greatly appreciated. Thanks.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Samsung HPR5072- No Power- No Standby
    Take a look at these 3 capacitors, they look like they are bulging.
    • fixitjunkie
      • Feb 2014
      • 39
      Which caps are you referring to? Attached is a photo of the Power Source PCB.
      Should I just try a used one? Thanks.
      • R_J
        • 9579
        These look bad (picture is not that clear)
        Just so you know, Vs and Va are DC voltages NOT AC
        • fixitjunkie
          • Feb 2014
          • 39
          Thanks RJ! I see the bulge on these caps compared to the others.
          Rechecked for DC voltage at Vs and Va. No voltage present.
          I'm going to order a used board and try it.
          • R_J
            • 9579
            With those 3 caps bad it is unlikely you will have any Vs voltsge
            • fixitjunkie
              • Feb 2014
              • 39
              This cap is on the Y-Main PCB.
              So these caps explode due to the surge...an acute failure?
              Do I need to address this failed cap before swapping the Main Power PCB and powering up?
              • tvtimmy
                • Mar 2015
                • 1160
                • usa
                They mainly fail due to age, you must replace every bulging cap to start with. One bad cap can shut down a tv. The one on the ysus can give you a bad picture. The 3 on the power supply are the reason the tv wont turn on. Replace them first as the are cheap compared to a new board. NOTE: THE NAME OF THIS FORUM IS BADCAPS.
                • fixitjunkie
                  • Feb 2014
                  • 39
                  Got it...Thanks!! So a new Ysus board is $120. Out came the soldering pen.
                  Some of the characteristics are obvious but not sure about the tolerance and some of the other letters. Some cap manufacturers advertise low ESR. Does this matter or will any manufacturer suffice?
                  • tvtimmy
                    • Mar 2015
                    • 1160
                    • usa
                    Get the low esr caps.
                    • fixitjunkie
                      • Feb 2014
                      • 39
                      I replaced three caps on the original power supply PCB and one on the Ysus PCB. Still no power or standby. Then, I swapped the original power supply board with a used one. IT'S FIXED! I'm still curious what failed on the original board. Maybe I should just accept victory and let it go. Thanks for the insight TVtimmy and RJ!! Will gladly be donating to the site.
                      • R_J
                        • 9579
                        The 3 bad caps were in the Vs circuit. If you have no STANDBY voltage, that is a different part of the board.
                        U101 is the standby ic, T101 is the standby transformer. Check for standby voltage on D108 cathode, it should be around 5Vdc. You can work on the power supply out of the tv but be careful as the primary side is connected to a/c line voltage.
                        • fixitjunkie
                          • Feb 2014
                          • 39
                          So I can wire a 120VAC bench source to the board and check for 5VDC across
                          D108?
                          • fixitjunkie
                            • Feb 2014
                            • 39
                            Rechecked the fuse again and supplied 120VAC to the board. No DC voltage
                            across D108.
                            • R_J
                              • 9579
                              You don't measure ACROSS the diode, you measure from ground to D108 cathode. Check the fuse F102, if it is open, ic101 is likely bad, (is it a, VIPer22A?)
                              • fixitjunkie
                                • Feb 2014
                                • 39
                                Fuse checks good. Checked for DC voltage on both sides of D108 to ground (used negative side of several capacitors for a ground point). No voltage present. It is a VIPer22A.
                                • R_J
                                  • 9579
                                  Check the voltage across C101, you should have 160vdc across the cap. Also check RT201 thermistor, it is likely around 10~20Ω but should not be open.
                                  • fixitjunkie
                                    • Feb 2014
                                    • 39
                                    Voltage across C101 - 165V
                                    Resistance across RT201 - 18 ohms
                                    • R_J
                                      • 9579
                                      The fault is likely U101, that circuit is fairly simple so there is not much that can go wrong. You could try replacing C104 & C170 and see if that helps. Check that R145 is not open and that ZD102 is not shorted.
                                      • Espartaco Smith
                                        TV Samsung UE40MU6405U, not standby (after power failure)
                                        by Espartaco Smith
                                        Hello, as I mentioned in the title, I have a Samsung TV at home, model UE40MU6405U, which is about 5 or 6 years old.
                                        After a power company failure, the TV stopped turning on and even the standby light wouldn't come on. Over a period of about 10 seconds, the electricity kept going off and on repeatedly, and the TV died.
                                        The power supply is: L40E6_KSM (BN44-00875A)
                                        The main board: BN41-02568B
                                        The power supply board seems to be fine. All the voltages are present. If I disconnect it from the main board, I get backlight.
                                        I've also checked the...
                                        12-17-2024, 02:16 AM
                                      • Chris24
                                        Samsung UN58J5190 - Doesn't Power on and has Standby
                                        by Chris24
                                        Hey everyone - I have a Samsung UN58J5190 with these symptoms: Does not power on, has standby light, standby light blinks 5 times after pressing "power on." When plugged in the power supply is making a very faint ticking sound, and this goes away when pressing power on.
                                        Following instructions from the great team here in recent posts for Samsung with similar symptoms, I did the following tests:
                                        I tested with mainboard disconnected from power supply - backlights do not come on (symptoms no change/5 red blinks)
                                        I tested with T-Con disconnected...
                                        10-12-2021, 12:43 PM
                                      • GLISIT
                                        by GLISIT
                                        01-16-2025, 02:29 PM
                                      • nathan425
                                        Samsung UN50EH5300 - No Standby LED, Backlights ON, No Power
                                        by nathan425
                                        Hello, I have a Samsung UN50EH5300 in my possession that I'm looking to bring back to life.
                                        Symptoms:
                                        • - no power
                                        • - no standby LED
                                        What I've done so far:
                                        - confirmed power supply is OK
                                        -- CN201 #4 showing 5.3V
                                        -- BD207 showing 5.3V
                                        -- removing the cable between the main board and the power board turns on the backlight.
                                        Pushing the power button on results in no change to any of the pins connecting the two boards.
                                        - function assembly appears to be NO GOOD
                                        -- there is no voltage showing on any of...
                                        11-01-2023, 06:34 PM
                                      • amennone
                                        Samsung UE50NU7090U , no power , no led standby
                                        by amennone
                                        By inserting power, on the diodes DM856...Dm859, there are 9 volts, when you press the power button the voltage is 12 volts, voltage present for a few seconds, then returns to 9 volts
                                        The power LED remains off, always.
                                        Reprogrammed Ic 503 = 25Q40 and IC 501 = 25Q80, downloaded from the site
                                        The situation remained the same​
                                        https://**************/dump/lcd_pdp_...oogle_vignette...
                                        11-17-2024, 04:28 PM
