Vizio E55-D0 help identifying "smoked" IC on main board
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Hi folks, I have this Vizio E55-D0 that will not turn on. After some searching I found this IC smoked on the Main Board. Unfortunately the numbers are burnt off too. The IC is board number UA5.
    Can anyone help me find a number for this? I'd appreciate it.
    They call me......."threadkiller"
  • petehall347
    • Jan 2015
    • 4451
    • United Kingdom
    Re: Vizio E55-D0 help identifying "smoked" IC on main board
    see if you can get a closer pic ..has to be in focus .
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      Thanks petehall347, hopefully one of these might work?
      • petehall347
        • Jan 2015
        • 4451
        • United Kingdom
        thats strange as i thought i could see some writing on pic 4 first lot of pics .
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          I looked at a ShopJimmy picture, the printing on the top is supposed to be yellow. I can't see any of it, even with a microscope.
          • petehall347
            • Jan 2015
            • 4451
            • United Kingdom
            looks like you need the schematic . will need resistor values etc for what connects to it as well .
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              Yes...looks like lots of casualties. Has anyone had any luck finding schematics for these?
              Time to scour the webs!
              • DXseekerMO
                • Feb 2018
                • 1119
                • US
                Well that went over like a lead balloon. I haven't found a thing. Vizio, release the repair information lol
                • R_J
                  • 9628
                  The best picture seems to be from SJ, the ic seems to be a TI ldo, these markings look similar (this ic's pinout is different)
                  • R_J
                    • 9628
                    The ic might be a Ti TPS54331 or TPS54231, the tps54231 has 12Vin, 3.3vout using a 10µH coil? Check if the resistors are close for this voltage
                    • DXseekerMO
                      • Feb 2018
                      • 1119
                      • US
                      The TV is put back together for now...I have 60 TVs to tear down. It's first on the list once that's done.
                      • cheeky2
                        by cheeky2
                        05-25-2024, 03:27 AM
                      • Dani_2024
                        by Dani_2024
                        10-28-2024, 05:06 PM
                      • gavric
                        Vizio M70-C3 Half picture is bad, main board on its last leg?
                        by gavric
                        Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                        When tv powers on vizio V logo shows nice on whole screen. picture 1
                        When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                        When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                        When i click video to start playing picture goes black(like when you change...
                        09-02-2021, 08:55 PM
                      • mrtek
                        Vizio M65-C1
                        by mrtek
                        Hi.
                        picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                        When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                        This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                        07-14-2025, 07:28 PM
                      • fharris1977
                        Vizio D50u-D1 Dead: PSU or Main Board?
                        by fharris1977
                        Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
                        03-12-2024, 12:22 PM
