LF320FX4F Mainboard
+ More Options
Posts
  • Eel_dahc
    • Apr 2017
    • 18
    LF320FX4F Mainboard
    I'm not a repair man, mostly a board swapper but have been slowly trying to be a board component swapper. I've had some luck with LF320FX4F tvs as I guess they are pretty common. Mom bought one that didn't work, so it sat. I found a cracked one in the dumpster and used the mainboard to fix hers. My nephew found one and I used the dumpster power supply to fix his. The power supply in his got a bad cap and I was able to use my moms as a reference to track that cap down and fix it.
    Now I found another on the side of the road and was able to track down a bad cap on the mainboard. IT's working but, it starts up with lines going down the center of the screen and after a few moments it pops up fine.
    Does that sound like a capacitor problem?
  • Eel_dahc
    • Apr 2017
    • 18
    Re: LF320FX4F Mainboard
    Well after repeated on/offs the lines actually quit showing up, so not sure what that was about. Also, I dug out the first mainboard from the first tv that I fixed years ago and low and behold the problem with it was two capacitors instead of one in the exact same spot. This mainboard made the power supply chirp, since both caps were bad and the other board that I fixed earlier just wouldn't display when turned on.
    • Mirenia
      Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
      by Mirenia
      I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
      I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
      In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
      The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
      03-30-2025, 06:47 AM
    • orcic
      MASTER TL240 and new mainboard LW36BKC01
      by orcic
      I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
      The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
      After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
      Now I have some doubts about how to connect the new mainboard to the old power supply.
      First of...
      05-12-2023, 08:10 AM
    • Devonavar
      Vizio M43-C1 - How closely do I need to match the mainboard number?
      by Devonavar
      I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
      I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
      Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
      So, I've ruled out the PSU for now.
      The reboot loop...
      08-14-2022, 08:46 PM
    • Malva
      Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
      by Malva
      I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
      Mainboard model: EAX65684604
      PCB marking: EBT62954607
      SPI chip: Winbond W25X20CLNIG Problem description:
      Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
      After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
      • I bought another
      06-25-2025, 02:07 PM
    • l0lhaxz1
      QN65QN90A - Mainboard MLCC failed - now bootloop
      by l0lhaxz1
      Hi
      I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
      Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
      Came to learn after a bit more research...
      02-06-2023, 08:59 AM
