Samsung UN65NU6900 hot cof's vertical lines
  • Kilroy2k1
    • Aug 2009
    • 69
    Samsung un65nu6900f
    I've had no luck scrounging a schematic for this unit so time to ask for community help.
    I bought this tv used and shortly after it started doing these vertical coloured lines over the entire screen.
    Another symptom is the COF tabs are super, super hot to the point of burning skin (dont ask how i know.. lol)
    Research has shown this was a common fault but I could not even locate the service bulletin that was mentioned.
    I'm hopeful someone has experience with this problem.
    voltages are as follows:
    VCC : 3.2v
    VCOM1 : 5.55v
    VCOM2 : 5.67v
    VCOM_REF : 5.5v
    VGL1_-5V : -7v
    VGL2_-10V : -14.9v
    VGH1 : 27.9v
    VGHD : 0.0v
    VDD_16v : 16.7v
    VCORE_1.2V : 1.12v
    Pannel_13V : 12.75v
    The only issue I can see are the VGL 1 and 2 are a little on the high side.
    Also the RT6950 chip that generates these voltages must be made for samsung as Richtek will not supply the datasheet so I cant verify any of that circuit.
    I hope I covered all the details, anything I missed let me know.
    Tom.
  • Nick's Tvs
    • Jan 2014
    • 621
    Re: Samsung UN65NU6900 hot cof's vertical lines
    Based on symptoms I would put money on the panel being bad. This is however something that can be fixed if the failure is located on the address boards.
    It would be nice if you could provide us a picture of the lines you are describing. The way the lines display on screen does matter and can point us in one direction or the other, so it would be nice to get a visual.
    Now on the address boards, you will either have a shorted SMD capacitor, burnt SMD resistors, or an IC malfunction.
    The first two are easily repairable.
    Disconnect the panel from the main board, and check the address boards for the above mentioned. I would start with resistors as those are going to be easy to spot visually. Just do a careful visual check on all the resistors and see if any look burned. They will be obvious and will fail open meaning they will have much higher resistance than they should.
    If no burned resistors are found, then check the address boards for shorted capacitors. If you find a shorted SMD ceramic cap, you will find most likely at least half a dozen others in parallel also showing a short. That however doesn't necessarily mean all of them are shorted. We usually carefully measure each cap very carefull and keep our leads on the cap for at least 10 seconds and notate exactly to the hundredth of an ohm the resistance of the cap. Once you do this for all of them, find the one with the lowest of the readings and remove it. That will be the faulty one. If multiple capacitors have identical readings, do a thermal test. Aka put your finger on all of them and see if any of them get hot. The one that gets hot is the bad one.
    If no burned resistors or shorted capacitors are found, then you may either have a bad IC, or I could be completely wrong and you may have a bad main board.
    • Kilroy2k1
      • Aug 2009
      • 69
      I forgot to add the detail in to what extent I have checked things out.
      I'll try to get and post a picture of the lines in the morning.
      I have gone over the address boards with a fine toothed comb, no shorted caps or open resistors. There is very little logic on the boards at all, just an eeprom and opamp i believe.
      It is all the cof's that get seriously hot and once they get hot enough the lines will appear.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4326
        • Italy - Milan
        You forget VGH2.. isn't there? is VGHD connected to GND?
        • Kilroy2k1
          • Aug 2009
          • 69
          Sorry for the delay,
          I dont find a VGH2 marked anywhere and I dont have schematics available to me so no idea if it even exists.
          VGHD is tied to ground yes.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4326
            • Italy - Milan
            Check D401/D404, i suppose D401 is connected to L401, if you can't figure out a problem, unsolder D401 and place on its cathode a tension of -10v with an insulated psu or regulated battery output and check the image. Check the resistance of VT404, i don't know what it is maybe a varistor, check resistance of R401-R402. If VT404 is not infinite unsolder it hand test the negative tensions.
            • Kilroy2k1
              • Aug 2009
              • 69
              I'll try and got to that tonight or tomorrow, i got some work in and of course the customer is in a panic. lol
              Welcome to Monday!
              Thanks for the direction and I'll get back with results soon.
              • Kilroy2k1
                • Aug 2009
                • 69
                Sorry for the delay, real life keeps getting in the way. lol
                Here is the photo as requested but i have not had a chance to do your other recommendation yet, I hope to get to it by tomorrow.
                • Kilroy2k1
                  • Aug 2009
                  • 69
                  I had some time to burn so i pulled out the meter, D401/404 test ok, 0.74 fw voltage, VT tests at 1.5K R402 also 1.5K. R401 Dead shorted! I removed and tested R401 and shes shorted. now for the fun part, finding its replacement value.
                  Anyone have a BN41-)2670A board around that can measure R401?
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4326
                    • Italy - Milan
                    I think VT is a varistor and must show open, but if you test in circuit you are measuring R402 instead so VT404 is ok, it's hard to say but try to swap R401 with a 1,5k, don't throw it away, could be a zero ohm.
                    • Kilroy2k1
                      • Aug 2009
                      • 69
                      I tried a 1.5K and then a 10K and it made no difference in the voltages.
                      I'll try and hook it up to a negative supply today and see how that goes.
                      This would be so much easier if Samsung would put out the schematics or even if richtek would release the datasheet for that chip.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4326
                        • Italy - Milan
                        I was searching for the resistor divider but it's not easy to find it. Otherwise the image don't tells me of a supply problem because the line colors are repeated in a pattern, so this brings me more to a logic problem, maybe ther's a flash eprom for the tcon part of mainboard, might be checked with a programmer and a dump from the web (russia)..
                        • bohaboha
                          • Nov 2012
                          • 973
                          • sweden
                          Hi Kilroy2k1 i had the same problem with a samsung 46 and i was advised by a member here to reflow the big chip and the 6 small ones around i have tried with it it worked for 10 mn because i did not let the mainboard cool down as it have to do.so now i still have the same problem and tv is waiting to be fixed.you can see in my posts
                          • Kilroy2k1
                            • Aug 2009
                            • 69
                            I'll be looking for a board to swap in for testing and see if there is any difference.
                            I had one lined up on ebay, but it was the wrong sub model, Lucky the seller was sharp and caught the error before sending me the wrong board.
                            • uniram
                              • Mar 2021
                              • 4
                              I know this thread is 6 months old, but Kilroy2k1, did you ever get any further on this one? I have the same issue and am about to begin trying to see if I can solve it. I started another thread before seeing this one (https://www.badcaps.net/forum/showthread.php?t=93917).
                              One difference I have is that the vertical lines on mine had a larger strip in between the repeating pattern. However, I no longer have anything but a black screen. I must have accidentally shorted something when testing. I have a new mainboard coming because I thought that was the issue until finding this thread.
                              I am going to go through this thread and the other one about the hot COFs and test all of the parts mentioned and see if I can get anywhere.
                              I am also attaching pictures of the 4 boards, labeled L1, L2, R1 and R2 from left to right. None of my COFs look like they have been damaged by heat.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                I’d start by checking all ceramic caps on the PCB for S/C they seem to be very common these days on panel driver boards.
                                • Stanley1843
                                  by Stanley1843
                                  06-29-2024, 11:54 AM
                                • x_orange90_x
                                  Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                  by x_orange90_x
                                  I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                  The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                  09-04-2023, 12:09 PM
                                • polaro
                                  Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                                  by polaro
                                  Greetings,
                                  I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                                  08-27-2022, 08:46 AM
                                  09-07-2024, 05:50 AM
                                • Anonmis
                                  Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
                                  by Anonmis
                                  Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
                                  The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
                                  12-01-2023, 04:31 PM
