Samsung UN65NU6900F - Sound and backlight but no picture
  • uniram
    • Mar 2021
    • 4
    Hi, I am trying to get this tv working. I hope I can explain this clearly, but if not, please ask and I'll try to clarify.
    I got this tv and it had vertical colored lines across the entire screen. I also found that if I touched the left cable from the main board when it was connected, I got a squeal from the main board and the vertical lines changed to noise.
    I tested the SMPS and all voltages were correct, as far as I could see. After that, I disconnected one of the cables from the main board (the main board and tcon board are combined in to one) to the panel to see if one or the other worked correctly. Neither one did (see attached images) though I found it weird that the screen looked basically the same - left side dark and right side white - whichever cable I disconnected.
    After disconnecting the cables and then re-connecting them, the tv now does not have anything at all on the screen. No vertical lines, no noise. The backlight is still lit and I get sound though. I also found that touching the left cable now does not produce any noise.
    So, my main question is, how can I tell if the issue is the main board (what I suspect right now) or the panel? Also, is there anything on the mainboard I can check electrically to see if I can figure out the issue? I haven't been able to find a schematic for the main board (BN94-12873J). I have attached a good pictures of the board top and bottom (from ShopJimmy).
    Any help would be greatly appreciated! Thanks, Steve
  • uniram
    • Mar 2021
    • 4
    Re: Samsung UN65NU6900F - Sound and backlight but no picture
    Here is a closeup of the connector and surrounding circuitry. Since I have no schematic, I'm hoping to be able to test this and figure out what voltages should be on what pins and possibly what components are bad.
    • rpw
      • Aug 2020
      • 1
      Hello, I've been fiddling with a similar model and came across a file that you may find helpful. It's titled "Samsung Panel Scree Repair Procedure V 1.7". Here's the link. https://kupdf.net/download/samsung-p...5377328edb_pdf
      • comptek
        • Aug 2013
        • 606
        • uk
        I would try taping up the clock (clk) lines
        Normally works for me try both sides though
        There plenty on YouTube showing how to do it
        • Pooshoes
          • Mar 2022
          • 9
          Did you end up finding a solution? I have the same model that is giving me trouble. I try blocking pins but can't find the right ones to cancel the error and allow the voltages to make it to the panel to turn on the screen. These ribbons have a different wiring than the usual fat ribbons for which I have a pinout for.
          With the screen ribbons disconnected all voltages check out fine on the mainboard (I might be able to help you out if you need some information what shows up where) but I can measure my 3.3V and 27V that would normally head to the panel. When connecting the ribbon the voltages will no longer turn on.
          I don't have any shorts on the panel that I can measure, but trying to figure out what handshake needs to take place or be blocked in order for the voltages to get sent to the panel so I can figure out what to do next.
          Thanks!
          • Unspun01
            • Jun 2011
            • 341
            I have same TV. UN65NU6900F. Terrible TV. Most likely a bad panel. covering clock lines may or may not work. you will need to remove the metal covers at bottom of screen and inspect the scalar boards at bottom of panel. There are 4 I think. Call them 1,2,3,4 from left to right as viewed from rear.
            They are connected to each other with small ribbon flex cables. 1 to 2, and 3 to 4. #2 and 3 connect to to TCONN as you have seen.
            On my TV, I would get backlights and no image at all times. some rebooting maybe.
            I could get audio to work and no rebooting by disconnecting ribbon cable 1-2. A closer inspection under magnifying glass showed visible arc/burn damage to one of my tab bond flex cables from scalar board #1 or #2 (I can't recall) to the panel. Not repairable in my case.
            I advise carefully removing the metal covers and inspecting your scalar board to panel flex cables. Also, they should get warm, but not searing hot. My bad one was very hot and I couldn't hold a finger on it for more than half a second.
            Try to check your TV and let us know.
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
            • Ierwin
              by Ierwin
              05-13-2025, 03:31 PM
            • jchang
              Samsung UN70NU6900F no picture and no sound
              by jchang
              Hi all
              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
              Symptom:
              No picture no sound.
              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
              No sound at all.
              What I tried:
              1. I tried unplugging the left or right ribbon...
              01-09-2023, 06:28 PM
            • marekk
              Samsung QE55Q67RAT no sound and bad picture when streaming
              by marekk
              I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
              I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
              Mainboard is based on pcb BN41-02695A BN94-14007B
              I will appreciate any help
              Many thanks
              Marek...
              05-29-2025, 02:23 AM
