Philips 32PFL3605\12 TPM4.1E LA No Power
  • trunks81
    • May 2020
    • 265
    • Nederland
    Hello
    Ive got an 32 inch where i see some strange things.
    There are no standby lights on the chasis, the blue led on the back of the smps lights up and slowly fades away.
    When board is connected in the tv the 5vsb is 5.3V
    And also the pfc is 386v instead of 400v, There is 12v and 24v only is 25,7v
  • trunks81
    • May 2020
    • 265
    • Nederland
    Re: Philips 32PFL3605\12 TPM4.1E LA No Power
    i found that an common problem is that U7106 is defective on the M/B !
    only when i measure mine iam getting 3.3V so that should be oke
    • trunks81
      • May 2020
      • 265
      • Nederland
      I whas wrong .. tv starts up but there is no backlight
        What Voltage do you have on at the EN (BL-ON) pin and DIM pin?
        • trunks81
          • May 2020
          • 265
          • Nederland
          Found the problem.. supply needs to be modified in order to work again!
          See solution in the attached files.
          • Sharpa
            Repair attempt Philips 55OLED804/12
            by Sharpa
            I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
            The symptoms when bought: Philips logo appears then tv turns off
            Things tried so far:
            1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
            2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
            11-22-2025, 08:30 AM
          • alro7779
            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
            by alro7779
            Hello, guys!
            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
            09-14-2025, 12:25 AM
          • G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
            by G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
            It does power up when pressing the power button.
            I already try the power button while plugin the plug with no result.
            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
            Could this be an PSU or eMMC issue ?
            07-19-2025, 03:43 AM
          • Francesc V.
            Christmas lights - Something I am doing wrong
            by Francesc V.
            Hi:
            i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
            I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
            If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
            Could...
            03-11-2023, 07:38 AM
          • double_DD
            Philips curling iron - is this a common AC cable?
            by double_DD
            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
            08-18-2025, 10:04 AM
