Re: Sony XBR49X900E no picture
So I just went over the entire post again and reread everything. At this point I think there is a good chance you got a bad main board. I think your new main board is defective.
If you want I can live test everything for you. Main board T-con and ribbons. We repair these main boards all the time, they often go out. I wouldn't be surprised if the board you got was from a cracked screen, but said cracked screen was tossed out in the first place because of a bad main board.
This is common and happens often.
I have this exact TV in the shop to live test the boards before and after repairs. As long as you can cover shipping the stuff I can plug it all up and at least confirm if the issue is the parts or if it is indeed your panel. I am more inclined to believe it is either the main board or the T-con or both than the panel.
DONE...why?...bad attitude.Last edited by nomoresonys; 10-29-2020, 10:22 PM.Leave a comment:
Did the hard reset as part of putting in the new main board. Also repeated it tonight. No change. Only difference Before & After the first reset was before the tv worked and you could switch channels and hear different stations sound. The picture or lack thereof actually was the same Before & After the resets.
Of course after putting in the new main board and doing the reset it no longer goes to the point where the TV is operational without picture it now goes to the point where it's trying to do the set up routine which I can't see because I can't see anything on the screen.
Is there another board in behind the black metal back of the tv?
I think a key clue in my diagnostics so far is there is no change in screen appearance with either one or both of the output ribbons from the tcon disconnected but no one has addressed that.Leave a comment:
how to make hard reset.. plug the set from wall socket while its ON, wait iminute and then press power and volume minus or joystick down keep press them while you plug it in wall socket again. release the key only when the front LED change from white to green.. leave it do what it wish it may restart 2 time.Leave a comment:
19.3v with tv on and Sony set up music playing. I ask again, what does a failed screen look like?Leave a comment:
They can be off, have seen them rated at 19 but checked at 16 or 17, a good one should read a little over 19 v.Leave a comment:
Put in the new Tcon board (the third including the original) and still no change. Did not check voltage of power supply, but have tried two different supplies and same appearance of screen. Will check voltage in next few days, I presume spec is the nominal voltage printed on the supply?Leave a comment:
Make sure your external powersupply is putting out the required voltage, sometimes just the least bit too low can keep things from working correctly.Leave a comment:
Finally got some time to work on the TV. jjanssen7 suggested "Have you tried disconnecting the ribbons between the tcon and the panel one at a time (with the TV off of course) and then turning it on?"
I did this and the TV screen behaves exactly the same as described earlier (no picture, slight glow appears in lower left with volume key press on remote, diffuse glow appears and moves around with up and down arrow presses on remote) with one or both ribbons between the tcon and the panel disconnected. Makes no difference in the appearance of the screen whether the ribbons are connected or not.
I am still leaning toward trying another tcon. What does a screen failure look like?Leave a comment:
So maybe I originally had a bad main board, it knocked out the tcon too. Then I bought another tcon put it in the set leaving in the original bad main board. The replacement tcon was knocked out by the original bad main board. Then I bought a new main board, put it in and the set still would not work because the replacement tcon board was knocked out by the original bad main board. So next step is to get another tcon board and put it in the set with the new main board?Leave a comment:
It is also rare but we have seen this before where the T-con failed. Don't know what on the T-con but we had a spare and we just tried it to rule it out but it ended up working. They are cheap so we didn't bother trobleshooting it to see exactly what was the cause of the issue. And this is in addition to the main board failing and needing to be replaced. Somehow the main board knocked out the T-con.Leave a comment:
Have you tried disconnecting the ribbons between the tcon and the panel one at a time (with the TV off of course) and then turning it on? Can't remember if this model will display half a picture at a time, but it's worth a try.Leave a comment:
Thanks for the reply. I did initially have trouble getting the update to "take" and renamed the file as you suggested based on something I saw in a you tube video, maybe yours. The update then ran and appears to have taken as the TV boots up to the point where the Sony set up music plays. Just can not see a picture. As to whether the ever ribbon and cable is functional, I unhooked and reseated them all.
The thing that stands out is no matter what I have done I get the same appearance of the screen. It goes from the "pure black" of the TV being off to the grayish blue when you start it up. And when I move the volume up and down (which works as the sound level of the music goes up and down) there is a subtle brightening in the lower left of the screen about where the volume bar would show up if I had a picture. It is like there is a little guy down over the edge of the screen in a cave shining a light upwards making the lower left of the screen glow a little. Also when I move the up and down arrows on the remote you can see some brightness spots (big diffuse areas about 20% of the screen size) that move up and down the screen when you press the arrows. This all was exactly the same before I replaced all the boards and reloaded the software as it it now is after.Leave a comment:
Sometimes when the main board is not paired properly, it can cause a no picture issue. I would suggest making sure every single ribbon and cable is 100% fully functional and running the update again. If the device already ran the update and doesn't want to anymore, you can press and hold the power button for 10-30 seconds or until it turns off and back on. This will force reset the TV and allow the update to take again. If that doesn't do the trick, remove the flash drive, change the file name to upgrade_loader.pkg and try again.
This should clear up the issue.Leave a comment:
Have a Sony XBR49X900E. Tree in yard was hit by lightning. Next day TV would not come on. Found external power supply was dead. Got a new one. TV worked fine. Few days later watching TV and picture went dark. Sound still OK, channels change OK, but can't see any picture. Still has some dark blue gray uniform glow to entire screen. Turn off TV. Next day turn on TV works normal for minute or so, then same thing, sound OK, functions OK but screen suddenly goes dark.
Do note that when TV comes on and see dim blue/gray glow if press volume control on remote, the lower left corner of screen brightens slightly. That (lower left) is where the volume bar graphic would appear if screen was displaying a normal picture. Volume does go up and down normally with the volume control, and channels change.
No difference no matter what input is selected, though I can't see what input it is as there is no picture. When hooked up to Direct TV box and I toggle to (what must be) that mode, the sound comes on with whatever channel Direct TV box is tuned to.
Do some research figure may be T Con board. Order one (used). Took TV apart, can see that backlight is on through the holes in the back of the TV.
Replace T Con board. No change, all symptoms the same. Someone at electronic parts online say sounds like main board. I get a new main board. Install, then have to download and install the software, get through that and TV starts normally no error flashing codes and gets to the music to set up a new TV, but no picture. I then replace all the other boards, LED driver, the little power board the external power 19v plugs into. Did not replace the WiFi board. Still no picture. Same glow in lower left if move volume up/down, can hear the setup music playing.
I tried unlocking the plugs for the flat ribbon cables going into the tcon board from the main board and wiggling the cables and had absolutely no reaction from the screen.
Any suggestions?Tags: None
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by crackedprintI have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
I have tried a Cold Reset as per the service manual.
I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
I have looked all the way through the service manual and tried many online...-
by CyberPhoenixHello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ? - Loading...
