Panasonic tx55as650b white screen.
  • vikivng
    • Feb 2019
    • 228
    • uk
    Hi guys,
    just need some input on this.
    Panasonic tx55as650b showing white screen on power on.
    T con voltages are as follows.
    FUSE=11.84
    V IN= 11.83
    VDD= .3V
    VGH= .2V
    VGL= 4.3V
    VCC= 3.1V
    Ill need to add more info tomoro but was hoping from these voltages something seems odd.?
    Especially VGH.?
    I get a constant clicking when I power on the tv.
    If I remove the larger (left side of tv)ribbon cable from main board clicking stops.
    Also if I remove the (right side of tv)cable on the panel side, the clicking stops.
    Also I get half screen much whiter with the other half of the screen black with colored verticals if I remove the same cable (on the panel side)that causes the clicking to stop
  • vikivng
    • Feb 2019
    • 228
    • uk
    Re: Panasonic tx55as650b white screen.
    Clicking seems to be coming from either main or tcon board.
      Is this stand alone T-CON board or integrated T-CON on the LCD panel?
      If it stand alone T-CON, what are those Voltages if the cables between T-CON and the LCD panel are not connected?
      • vikivng
        • Feb 2019
        • 228
        • uk
        Hi bud,
        thnx for replying.
        Yes its a standalone board.
        I sense bad panel news coming ?
        voltages are as follows,
        V IN=11.92
        VDD=15.62
        VCL=5
        VGH=28
        VCC=3.3
        • vikivng
          • Feb 2019
          • 228
          • uk
          With the left side of tv cable (panel to tcon) connected.I get the same voltages as when both cables disconnected (normal?)and the buzzing/clicking stops.
          Also this is when half the screen is very white and half black with vertical lines.
          Voltages go back lower with the right side connector connected and also the clicking resumes.
          The whole screen also goes back to the white/grey.
          I assume the problem is on the right side panel flexible board.?
            You have panel problem, hopefully just some bad MLCC on the tab bonding boards, just start checking the resistance of the MLCC.
            • vikivng
              • Feb 2019
              • 228
              • uk
              Thnx ,,thought so,
              should they have pretty much the same resistance of the same size.?
                You will be looking for low resistance reading. MLCC failure mode is shorted or bad leakage resistance.
                BTW, in theory cap has infinite resistance.
                • vikivng
                  • Feb 2019
                  • 228
                  • uk
                  ok thnx
                  • Chrissygizmo
                    Panasonic TX-48CX350B backlights but white screen , blank screen
                    by Chrissygizmo
                    Hi all, I’ve got a problem I hope someone can help me fixi.
                    I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                    01-11-2025, 03:18 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • harp
                    White screen repairs
                    by harp
                    To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                    Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                    On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                    05-13-2024, 03:43 AM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • longmt1990
                    Panasonic Cf-w5 bios password remove
                    by longmt1990
                    Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                    I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                    Please help me remove bios password.
                    Thank you so much
                    07-06-2025, 10:50 PM
