Samsung UN40D6000SF
  • charlie555
    • Feb 2018
    • 76
    • usa
    Samsung UN40D6000SF
    Getting double image or ghosting any advice?
  • neilc6
    • Nov 2015
    • 1550
    Re: Samsung UN40D6000SF
    Connect one side of the tcon to panel ribbon cables one at a time and see if one side displays a good picture. If so, you can try the tape cutoff method on the bad side by blocking the outer pins with scotch tape.
    • charlie555
      • Feb 2018
      • 76
      • usa
      Ok, so with the panel face down, unplugged right side, left side looks good. Switched and bad on the other. Tape on which end and how many pins should be covered.
      • neilc6
        • Nov 2015
        • 1550
        On the bad side, tape over 2-3 pins to start on the outside edge. Increase by a few more pins at a time. Repeat if picture is still bad. Unplug tv between attempts. If still bad, you can rip off the side tabs on the bad side if it has them as last resort.
        • charlie555
          • Feb 2018
          • 76
          • usa
          Ok will try, ty
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4542
            • Italy - Milan
            Don't go at random, post the TCON model code, if i can i will inspect a good photo in the web...
            post also a photo or two of the video defect, don't be superficial..
            • charlie555
              • Feb 2018
              • 76
              • usa
              last pic is with the screen facing down and the right side ribbon cable in place with slite pressure on the the latch.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4542
                • Italy - Milan
                The photos are not so good, if screen is in landscape position the camera must be the same, if i see well there's a top portion well visible and a line that divides the bottom doubled image. If yes try to insulate with tape first CKV1,CKV2,CKV3,CKVB1,CKVB2,CKVB3 in turn, if it doesn't work try VCST,VST, VSS in turn. Theese signals are repeated in both connectors.
                • charlie555
                  • Feb 2018
                  • 76
                  • usa
                  Ty
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4542
                    • Italy - Milan
                    Sorry, i have forgot to say that the signals must be insulated on the faulty side only.
                    • charlie555
                      • Feb 2018
                      • 76
                      • usa
                      when you say the edge , left edge or right?
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4542
                        • Italy - Milan
                        Are you writing to me? I've never said edge.. if you are asking which side to treat is obviousy the left side wathcing the screen as normal...
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                          09-07-2024, 05:50 AM
                        • alltvrepairs
                          Hisense 55AS6G screen double sided tape required
                          by alltvrepairs
                          I need to replace the LEDs of this TV. The screen is glued with double sided tape. This video shows the proceudre required.
                          I need a source for this type of double sided tape adhesive please.
                          https://www.youtube.com/watch?v=bN6g...nel=QUADRA-NET
                          Tks!
                          07-17-2025, 09:32 AM
                        • valvashon
                          Samsung UN60JU6500, stripe on left side of screen
                          by valvashon
                          Friend sent me this picture of what their 60" Samsung from 2015 is doing. I didn't have any luck getting rid of a vertical stripe in another TV that developed one so I'm not too excited about trying to fix this one. It's mine for the asking; wish it had a dead power supply or bad backlights instead.
                          Is this most likely to be a connection at the circuit board or where the ribbon cable hits the screen itself?
                          Update: was just informed that this stripe comes and goes and has been doing this for a couple of months.
                          Thanks, Val
                          Today, 03:01 PM
                          09-06-2024, 11:40 PM
