power up "TV power supply without logicboard
+ More Options
Posts
  • senakahks
    • May 2020
    • 39
    • New Zealand
    Isolating power supply issue is something very useful. As a beginner I have following questions regarding inputs to power supply.
    As I understood PS_ON, DIM and BLK_ON are inputs to the PSU.
    These are my problems.
    1. Can we turn on power supply without logic board by connecting following pings?
    * 3.3V STB and BLK_ON (via a resister) AND
    * Connecting 3.3V STB to PS_ON for a short period
    2. Do power supply sense current to the logic board and T-Con?
    Can we turn on power supply without backlight (with logic board connected or not)?
  • senakahks
    • May 2020
    • 39
    • New Zealand
    Re: power up "TV power supply without logicboard
    I found this answers some of my questions.
    https://www.badcaps.net/forum/attach...8&d=1555746469
    Still others ideas are appreciated.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8088
      1k resistor from stby to pson,
      1k resistor from stby to blon, and mayby the dim pin.
        No connection to the main when perform stand alone self test.
        If the power supply board has inverter for CCFL BACKLIGHTS build in then you need to have lamps connected, if it has built in LED driver then you can test without LED connected but the LED driver will go into shutdown due to no load to the LED power supply when you apply BL-ON.
        You can do force on of the power supply using PS-ON just to test the switched power supply section, when you you do BL-ON test, you need to have Lamps (CCFL backlights type), or LEDs connected.
        Basically, you need to know what kind of power supply board you are testing, does it have inverter built-in, does it have LED driver built-in... etc.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
          07-01-2024, 06:34 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
        • CMCM
          Russound CA4 Power Supply Repair
          by CMCM
          Hello Everybody,
          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
          The outputs marked 12v and 20v are all measuring only 1v.
          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
          The capacitors physically look clean (no bludgesor leaks) and...
          07-03-2025, 01:12 PM
