Samsung BN44-00264A Power Board
  • cicabu72
    • Oct 2016
    • 32
    • Italy
    Re: Samsung BN44-00264A Power Board
    Important update
    I replaced STRW6252 with another spare part I discovered at home and TV now is powering up and shows channels, but.. it only lasts 10-15 seconds, then shuts off, standby led blink some times and TV restarts, in a sort of loop!
    I feel we're very close to the solution, time to replace also CM808?
    • R_J
      • 9627
      I would replace CM804 and CM808, and even CM809 & CB804 while you are at it. Those small caps dry out over time but will look amd sometimes check ok.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4544
        • Italy - Milan
        Keep consideration that there is a story of defective STRW sold on market, you must take them from reputable markets, like Farnell, Distrelec, RS, or at least UK sellers on ebay. You must also test psu at bench with dummy loads.
        • cicabu72
          • Oct 2016
          • 32
          • Italy
          Replaced CM804, CM808 and CB804, now TV stays ON for a longer period but after 5 minutes the loop reappears. I did not find CM809, also looking at schematics, were you referring to another capacitor?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Turn down the backlights as low as you can go and still have a reasonable picture and see if it stays on longer.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4544
              • Italy - Milan
              #26
              and this what means?
              check the connectors of cable between psu and main, it may have burnt pins like the b620 that i have fixed (same psu)
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #27
                My error. It's a CCFL set not led so ignore turning down backlights.
                • R_J
                  • 9627
                  I must have made a mistake on CM809, I likely ment CP809, The small caps on the VCC lines for the primary ic's.
                  Check the voltage across CM804 and then check the voltage on QB801 emitter using hot ground. (or check the voltage across CP809) This voltage should be about 16vdc, These voltages will tell you if you have a high enough vcc for the ic's to stay working.
                  • cicabu72
                    • Oct 2016
                    • 32
                    • Italy
                    #29
                    Hello there, some updates after summer holidays
                    - Installed a brand new STRW6252 (the other was a spare part, I was not really sure if it was working properly) = same random reboots
                    - CM804 (replaced) reaches 18.1V when TV is ON, when a reboot appears, it drops to 16.8 and then come back to 18. I noticed that after a reboot (red power led flashing), additional reboots may also appear until TV stays ON for a while
                    - CB804 (replaced) stays all the time to 0.03V, is it normal?
                    - CP809 (replaced) but I have to test the voltage yet, the position is a little bit tricky, so I need some test clips
                    - I get weak signal on the channels I am watching just before a reboot, remote become unresponsive, could be this a sign that some voltages are dropping (normal conditions 12.50 on 13V and 5.1 on 5.3V, all measured on CNM802, way too low?).
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4544
                      • Italy - Milan
                      #30
                      Read BETTER comments, i told you to: " You must also test psu at bench with dummy loads", this test is mandatory, tell me why you have to search for a board error if you don't even know if you have an error... i told you also to check cable connectors, read back..
                      • cicabu72
                        • Oct 2016
                        • 32
                        • Italy
                        #31
                        I checked the pins from both side and they seem fine, multimeter in continuity mode beeped at every pin.
                        Anyway, today I disconnected the cable from the main board and the backlight was fine for one hour. How can I test the PSU with loads, do I need some specific equipment? Bear in mind that this is not my work, TV is mine
                        Nevertheless, I am now suspecting that the main board is not working properly, I told you about the weak signals just before a reboot, the unresponsiveness of the remote, but today connecting an external HDD to USB port caused many unsuccessful starts until I disconnected it (power led red flashing). Weird
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4544
                          • Italy - Milan
                          #32
                          You need only power resistors, for the standby 5v you can load 1A, 5v/1A=5ohm/5W, 5V*1A=5W.
                          For the A5V you can load 2A so 2,5ohm 10w, for the 12v at least 2A, since there are not all the resistor you want take example 2 10W, so 20W/12V=1,8xxA , 12/1,8xxA=~7ohm/2=~3,3ohm/10w x2 in series.
                          For 12v you can use a 12v 20w ceiling or car lamp, halogen
                          • cicabu72
                            • Oct 2016
                            • 32
                            • Italy
                            #33
                            I connected a 12V 40W halogen lamp to 12V connector CNM802, I can say that the lamp stayed ON for 1 hour with the same intensity. Power board seems stable in this condition, but I noticed that I am not getting 12V but 10.3V (on the connector) and 9.5V on the pins towards the lamp. The only connected load is the lamp right now, as you can see in the image. What do you think, should I proceed with 5V tests?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4544
                              • Italy - Milan
                              #34
                              The board must be load on all outputs, 1h is too much time, needed only 1min. and see the voltage across load, anyway since the 12v and B5V comes from the same transformer i guess there's a problem in the feedback components, change the tl431 small TO92 component and the optocoupler connected to it.
                              • cicabu72
                                • Oct 2016
                                • 32
                                • Italy
                                #35
                                Do you mean QB801? What is the optocoupler name in the circuit?
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4544
                                  • Italy - Milan
                                  #36
                                  I can't judge by a photo, and my board is too much "infognated" :-)))), check under side across the thick black line there are 3 - 4 pins components one attached to the other, them are optocouplers, watching that zone there are some sot23 components, one is marked 431 on the body and Uxxx on the position, that is the tl431 i mentioned and is pin connected to the right opto. Good luck..
                                  • cicabu72
                                    • Oct 2016
                                    • 32
                                    • Italy
                                    #37
                                    QB801 (on the front) has D1347 C K913 on it and seems to be a TO92 component. Can you tell me if you see the optocouples in the attached image (back)? Thank you!
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4544
                                      • Italy - Milan
                                      #38
                                      Leave alone TO92 package, i was expecting that but 431 is in format sot23, search it to the right of those three opto in your last photo.
                                      • cicabu72
                                        • Oct 2016
                                        • 32
                                        • Italy
                                        #39
                                        I think I found it, UM801, in the scheme is marked as KA431SLMF2, but I was not able to read tl431 on top of it. In the attached image you can see it, is it possible to do some test with a multimeter before replacing it?
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4544
                                          • Italy - Milan
                                          #40
                                          My last mess. seems lost... as i've said it is printed only 431, it has a pin connected to the right opto
                                          checking it is.maybe possible but to be safer better to replace it.
                                          • Cooperr
                                            Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                                            by Cooperr
                                            I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                                            The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                                            10-21-2025, 01:11 PM
                                          • C152Heavy
                                            by C152Heavy
                                            Summary for TL-DR readers:
                                            • VCC pin (18) of PFC...
                                            01-11-2023, 02:53 PM
                                          • Destroyer-Br
                                            [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                            by Destroyer-Br
                                            I'm working on an Acer Nitro 5 unit with the following specs:
                                            • Motherboard: LA-J871P Rev: 1B
                                            • Model: Acer AN515-55-59MT
                                            • S/N: NHQ7JAL00403906A973400
                                            • SNID: 03902728734
                                            Initial Issue
                                            The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                            After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                            04-17-2025, 08:18 PM
                                          • Nicktronic
                                            Samsung Power Supply Board BN44-00874F
                                            by Nicktronic
                                            Hey everyone,
                                            This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                            Anybody...
                                            03-17-2025, 06:20 AM
