Westinghouse WD48UW4490 Scrambled Video
  • neilc6
    • Nov 2015
    • 1550
    This TV has scrambled video on all sources including apps but the on screen display is unaffected. I assumed a bad main board, got a replacement but still have the same issue. It's a 4K panel but has a second board between the main and tcon, a FRC (Frame Rate Control) board. Not familiar with this setup. Can the FRC cause the scrambled video? Animated gif attached (click to animate). Also stock photo of the FRC board.
    Re: Westinghouse WD48UW4490 Scrambled Video
    FRC board can cause video refreshing issue.
    Did you try heating and cooling it and do some Voltage testing yet?
    • neilc6
      • Nov 2015
      • 1550
      I buttoned up the TV thinking the new main board would fix the problems. Will need to open it back up again. It does run clear for awhile so I can try cooling it. Reason I suspected the main (ordered without opening up the TV) is because the on screen menus are fine so it can't be the tcon nor panel.
      • neilc6
        • Nov 2015
        • 1550
        Got a new FRC board today and no scrambling so far (knock on wood). When I replaced the main board previously, I had the back cover off so suspect a thermal issue with the FRC board. Plus it was a hot day. Cooling it beforehand would also make it run longer before scrambling occurred.
        These newer RCA/Westinghouse models have a redesigned menu and it looks like the backlight level adjusts with the brightness level. Didn't find a backlight setting in the service menu. And none of the picture modes set the backlights to max by default.
        • RinusB
          • Sep 2017
          • 17
          The RCA RTU6049 has a similar issue. The TV is good in my cold basement area but with the back on, the image goes black. No backlight and no picture. (tested to make sure)
          The heatsink on the FRC board goes to 130 degrees (54c) and stays hot after the screen goes off.
          Everything works great so cooling that chip is an issue.
          Maybe I get a new FRC board or just replace that IC. I am sure the issue is one and the same.
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
            by JDC
            ONN 100012588
            Issue: No Power, Then Rebooting After Main Board Change
            Short answer: replace main board and power board
            Technical answer: replace main board and Q306 & Q307 on power board.
            Long answer:
            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
            07-15-2022, 07:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
