LG 42LB5600 standby light works but no picture and clicking sound
  • jmandawg
    • Jul 2020
    • 42
    I have a LG 42LB5600 when plugged in the red standby light is illuminated. i can hear a faint clicking sound coming from the part# 14S-LM01 (transformer? in middle of the board) When i press the power button, the standby light turns off but the display does not turn on.
    I do get voltages across the fuses and the large caps (did not check the small ones) but no voltage out the led power (top red and black wires).
    Did not see any burn marks or bulging caps.
    The faint clicking is only when the TV is turned off.
    Any ideas?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 42LB5600 standby light works but no picture and clicking sound
    Can you give the voltages on the connector as shown on the circuit board
    eg
    Pin No. Name Voltage
    Pin 1 GND 0V
    Pin 2 ON/OFF 3.5V
    PIn 3......etc
    and what volatge do you have between the two legs of C610
    • jmandawg
      • Jul 2020
      • 42
      i can only test the pins on the top without turning the board over. Here's what i got from top pins with tv turned on:
      pin1 GND: 0
      pin2 12v: 11.91
      pin3 12v: 11.91
      pin4 GND: 0
      pin5 24v: when i touch the prob to it it's goes from a voltage around 17v and immediately drops to 1v
      pin6 GND: 0
      pin7 3.5: 3.5
      pin8 3.5: 3.5
      pin9 PWON: 3.3
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        How about DRV_ON. There are two sets of pins running in parallel on that connector so I think you missed out some of the readings.
        You need to check the diodes under the silver heatsink. Use your meter in diode mode.
        If this is similar to your power supply can you check the two items identified
        • jmandawg
          • Jul 2020
          • 42
          Here is a pic of the underside of the board. and here are the other set of pins:
          pin1 GND: 0
          pin2 NC: -
          pin3 12v: 11.91
          pin4 G: 0
          pin5 24v: goes from around 17 -> 1v when touched with probe
          pin6: NC: -
          pin7 3.5: 3.5v
          pin8 P-DIM: 1.2v
          pin9 DRVON: 3.10
          • jmandawg
            • Jul 2020
            • 42
            I check the 2 transistors in your image. I'm assuming i do it with the TV unplugged.
            for the first one with the arrow: no reading between left and middle pin, but i got a reading between middle and right pin. (and same thing for the transistor right above it)
            2nd one with the box around it. I got a voltage reading from left to middle and right to middle.
            Please let me know if i'm testing them wrong.
            • Diah
              • Feb 2013
              • 6435
              the 24V drops down after seconds.. mean you need to test the LED socket red probe on red and black on black then turn on.. i think it will goes high and drops down if there re shorted LED. TV will not starting.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                What were the readings. Can you see the part numbers written on them?
                • jmandawg
                  • Jul 2020
                  • 42
                  yes i just tested, when i turn the TV on the LED output jumps from 19v and then back down to zero. Do you think it's still worth trying to fix?
                  • Diah
                    • Feb 2013
                    • 6435
                    its tell you have one shorted LED so the set went to safe shutdown.. take the screen apart and put it at safe place .. check which LED wont lid at start up and replace it... the set still can work with out LCD in place.. so the checking and repair easy.
                    • jmandawg
                      • Jul 2020
                      • 42
                      the thing is even with the LED connector unplugged the voltage still goes from around 19v to 0v on startup. Shouldn't the voltage stay on when the connector is unplugged?
                      • Diah
                        • Feb 2013
                        • 6435
                        NO, the LEDs strings are parts from the circle circuit.
                          1) Post #2 ask about the Voltage on the main filter cap C610.
                          What do you get when measure the Voltage right between the two legs of the cap when TV is turned on?
                          2) What do you get when measure the Voltage right between the two legs of the cap C224 when TV is turned on?
                          • jmandawg
                            • Jul 2020
                            • 42
                            C610: 393v
                            C224: 193v
                            i took the panel apart only to realize i don't have a 24v power supply to test the LEDs.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Are you certain that C224 reads 193V. The capacitor is rated at 160V ?
                              • Diah
                                • Feb 2013
                                • 6435
                                C610: 393v
                                C224: 193v
                                you can see them with eyes which one not lid.. you can record movies to see it correct as it is could for less second
                                • jmandawg
                                  • Jul 2020
                                  • 42
                                  the readings on the top one (with the arrow) was 532 (not sure of the units) on the middle and right pin.
                                  the bottom one with the square was 180 arcoss the middle and top and also 180 across middle and bottom pins.
                                  the part number for the top transistor is:
                                  MD3752
                                  F9004HGE
                                  The bottom transistor though the hole i can read:
                                  KMBRF20
                                  U100CTA
                                  • neilc6
                                    • Nov 2015
                                    • 1550
                                    I'll help with Diah's English translation. The TV will power on with the panel disconnected and you can watch the LEDs flash to see which one is not lighting up. You can record it on video and go frame by frame if it is too quick.
                                    I will add with LED problems, it is better to replace all the strips with new. They all have wear and the ones still working are likely to fail. With the LB series, the heavy lenses also tend to fall off with age.
                                    Here is a good analogy. My right side low beam burnt out on my car so I replaced it but bought a spare since I expected the left side to go as well. Sure enough, a couple of months later the left side went. My daytime running lights have more hours on them and use the same bulbs but I don't expect them to fail. Why not? Because they run dimmed around 40% of maximum. Same thing applies with LED backlights except of having 2 bulbs, you have a string of many.
                                    • Diah
                                      • Feb 2013
                                      • 6435
                                      thx neilc6
                                      • jmandawg
                                        • Jul 2020
                                        • 42
                                        i don't see any of them turn on at all.
                                        • B0r1s
                                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                          by B0r1s
                                          PSU - BN44-00878A
                                          Symptoms:
                                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                          A weak clicking sound was coming from the transformer.
                                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                          Progress:
                                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                          01-17-2023, 04:58 PM
                                        • slimsoul
                                          Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
                                          by slimsoul
                                          Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
                                          I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
                                          I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
                                          The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
                                          03-12-2024, 03:55 AM
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          Yesterday, 02:18 PM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:33 AM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
