Onkyo-593 No power and now clicking sound
  • Sisko
    • Apr 2020
    • 5
    Hi all!!
    Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify this resistor and on the board it is marked with this symbol; "W" yep a w just as if it was a fuse but it's not that soldered par has an R. Ok just looked it up on the microscope and I can't see any writings at all BUT I do see 3 bands one is thin and the other two are bigger and since its burnt the bands are black as you can see in the photo. So now what? any help with this would be very appreciated!!
    UPDATE!!
    Ok Replaced a few parts but now getting a "clicking sound" when powered on and yes I am plugged with a dim bulb thing. For now I know it's in "protection mode" did lift pin 12 VCC on the IRS2092 and two big caps (and other parts in the red section) and I get 0V BUT when it's clicking I get very faint voltage readings. So right now I have no idea where to look for. I did ESR on the 4 big caps and all checks out ok and did voltage test on the longest 2 caps but not getting voltage because of the clicking sound. Before changing the parts (3 parts pic) that weren't good it wasn't clicking at all but after it started to click. I'm trying to learn to fix electronics as much as I can but this one is a bit hard to find the problem but I'm asking you PLEASE no jokes or stupid answers. I have provided schem, parts changed and a pic of the section that is causing the problem. Any help would be very welcomed.
  • madan1
    • Nov 2016
    • 708
    • Bulgaria
    Clicking usually means that the smps can't boot.
    Show on the schematics where is the "W" part.
    • B0r1s
      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
      by B0r1s
      PSU - BN44-00878A
      Symptoms:
      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
      A weak clicking sound was coming from the transformer.
      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
      Progress:
      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
      01-17-2023, 04:58 PM
    • slimmy182
      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
      by slimmy182
      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
      Looking on google I found this:...
      01-14-2023, 11:55 AM
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • Solvik
      XFX XPS 650w 3XS PSU making Ticking/clicking sound
      by Solvik
      Hello
      i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
      All voltages are normal....
      02-13-2025, 02:43 PM
    • nbnb
      Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
      by nbnb
      I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
      Any idea what is causing the clicking sound? Any easy way to...
      11-23-2019, 12:03 PM
