Samsung horizontal line
  • uksparky
    • Aug 2020
    • 8
    • usa
    Hi all my first post samsung 65'' tv model UN65NU8000 FXZA
    Version FD04
    I have the horizontal line about fifteen inches from the top, its not a constant line but broken up, i noticed today close up the lines go all the way to the bottom but they are hard to see... and the color is not right other than that its ok... six months out of warranty... Could it be one of the two main boards if these parts dont work it must be the panel screen, the ribbons look ok .. will these parts fix my problem, the lower board looks like its part of the screen and can not be removed....done the tv re set and trouble shooter....
    Repair shop is one hour drive in my truck... i would like to have a go if that dont fix i will leave it the way it is. I can get both boards for $99 from ShopJimmy.com..
    https://www.shopjimmy.com/samsung-un...=instocknotify
  • uksparky
    • Aug 2020
    • 8
    • usa
    Re: Samsung horizontal line
    notice the pink color on forehead above the line
    • uksparky
      • Aug 2020
      • 8
      • usa
      Re: Samsung horizontal line UN65NU8000 FXZA
      anyone
      • budwich
        • Jul 2015
        • 3097
        high probability that is a panel / driver problem. check the sides to see if it is designed with tabs and then check to see if any of those are compromised.
        • uksparky
          • Aug 2020
          • 8
          • usa
          Thanks budwich ..can you explain as i am not a tv tech ... you said check the sides.. what tabs are you talking about ?... i was guessing the panel was the problem, is it worth spending a hundred bucks.... almost got it paid off at best buy owe $165 lol
          • Diah
            • Feb 2013
            • 6557
            to me from first photo this line wasn't panel fault or pixel. its much like noise so first i suggest you try..
            1- clean the LVDS between Main boards and T-CON boards
            2-Clean the ribbon cable between T-CON and panel
            • uksparky
              • Aug 2020
              • 8
              • usa
              Thanks Diah .. when i had the back off i did check clean the ribbons and wires to the 2 boards but did not pull the metal cover to the T-CON and panel ribbons as i was not sure how to get it off... later on i found out.. i was hoping the board wires were the problem.... when i pull the back off again i may as well replace the two boards and check the panel ribbons... then i will be done with it... looking on youtube there is no T-CON on my model, just the two main boards and under my metal plate at the bottom what i see was a long board with ribbons to the panel, can you confirm this
              • Diah
                • Feb 2013
                • 6557
                by the way did this noise of line showing up when you use for example USB media content like movies or jpg HD or UHD photos ?
                • uksparky
                  • Aug 2020
                  • 8
                  • usa
                  noise of line lol ..what is that.... I had samsung help me with troubleshooting, removing the direct tv cable in etc ... nothing worked... line on tv came one next night when i turned it on...not when watching .. no to what you said above..
                  • Diah
                    • Feb 2013
                    • 6557
                    using usb or other source are trouble shooting to narrow the issue... as you took it in fun way.. then judgment of the issue from budwich are in place.. enjoy
                    • budwich
                      • Jul 2015
                      • 3097
                      as suggested by diah, input a good source... get a test pattern (eg. smpte color bars or equivalent... can be found on the net as computer files or on some DVD disks as extra material). This will provide a "static display" which can be used to highlight issues to help with seeing what's up with the display. Further, you need to provide a picture of the back of the set showing how everything / cards are connected up.
                      • Ihandyrepair
                        Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                        by Ihandyrepair
                        Hi guys
                        I just started fixing 4k TV few months ago. so I am still learning a lot
                        I got this tv from friend complaint is ghosting or horizontal lines on image.
                        never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                        then it started to show the ghosting white image.
                        I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                        it has 3 thin small boards at the bottom of the...
                        12-05-2022, 04:18 PM
                      • cubytus
                        Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                        by cubytus
                        Hi to all,
                        I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                        I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                        Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                        01-10-2024, 01:26 AM
                        09-07-2024, 05:50 AM
                      • kotel studios
                        Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                        by kotel studios
                        Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                        In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                        08-06-2025, 02:07 AM
                      • madyoyo
                        Samsung eu58tu6928k - Short on CK3 line -
                        by madyoyo
                        Hello.
                        I have a Samsung eu58tu6928k with the dreaded bootloop fault.
                        No external tcon, one 96 pins ribbon between mainboard and the left side of the panel, and a ribbon to the right side.
                        I narrowed the problem down to the CK03 line. When i isolate only this line on the ribbon joining the 2 halves of the panel, the tv boots, but the picture is quite bad. I also tested all MLCC caps on the panel, no short so far. Is there anything i can try before ruling the panel, and the whole tv as scrap?...
                        11-05-2025, 04:55 AM
