Soniq E48W13A-AU Bad P/Supply
  • saddle_au
    Waste Warrior
    • 121
    I have a Soniq 48 inch LCD TV Model E48W13A-Au which is suffering from severe heat issues on the P/S in the area of the led drive. The TV tries to wake up from standby, but doesn't get past switching off the red standby led.
    Most of the output caps have popped due to the temp coming from two what I think are diodes located under the board (guess which spot!!).
    1) Has anyone seen or dealt with this before?
    2) Does anyone have a Megmeet MP48-QG schematic?
    3) I don't know what the parts underneath actually are, I think diodes, but I cannot find references to D458 or CA3316 anywhere.
    4) I might suspect the leds in the panel caused this grief, but I would like to give the P/S a go first before tearing the panel open.
    Any and all help appreciated.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Soniq E48W13A-AU Bad P/Supply
    It's a mosfet.
      Please attach good clear straight shots pictures of the whole bottom side of that power supply board.
      • saddle_au
        Waste Warrior
        • 121
        Hope these are clear enough, there's a 2000 dot limit on the file size.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          I wonder if they overheated due to the capacitors high ripple current due to the capacitors failing over time.
            That is boost converter section, if those filter caps for feeding the B+ to the boost converter were slowly loosing capacitance, then the circuit will not be running at the design frequency due to modulation between power supply frequency and the boost converter frequency so the circuit will draw more current. If some of the LED shorted out (there are two LED strings), I will then expect the PWM controlled MOSFET's on the heat sink will get hot.
            I also hope that the boost conductor core is not damaged by the heat.
            At this point did not indicate if those two MOSFET's for the boost converter are OK or not, if they are not shorted out and tested OK then he should replace the caps and see what will happen.
            • Vandalyst
              • Mar 2022
              I just came across this post and I noticed my board has discolouration at the exact same location ...
              Was this problem fixed by replacing Caps?
                • 12200
                • U.S.
                are the tops of your caps bulging at all, hard to tell from picture, if they are replacing all of them is where to start and might be all that's wrong.
                • Vandalyst
                  • Mar 2022
                  I have replaced all the caps but the tv won't power up ..
                  it still is stuck at standby
                    • 12200
                    • U.S.
                    check those diodes right there in that burnt looking area, check those 2 components on the heatsink there, how does that area look on the underside of the board?
                    • caspian
                      What Zener Diodes on a Linear Power Supply
                      by caspian
                      Dear members,
                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                      In addition, I discovered that its zener diodes are defective.
                      I can replace the burned transistors.
                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                      Therefore, I cannot replace the zener diodes.
                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                      no schematics are available...
                      05-26-2025, 12:38 PM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                    • Yanleb
                      UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                      by Yanleb
                      My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                      Disconnecting the main board from the power supply makes the backlight come ON.
                      I did disconnect the panel cables and the WIFI modules, the board is still dead.
                      I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                      Thanks.
                      11-18-2024, 12:34 AM
                    • reessi
                      JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                      by reessi
                      I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                      You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                      Years ago it had some bulging caps...
                      04-26-2021, 11:42 AM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
