digihome ptdr24hds3 backlight only no picture
  • petehall347
    • Jan 2015
    • 4439
    • United Kingdom
    this one landed here . owner said he plugged in a lightening connector converter to hdmi then the picture and sound went off . i am wondering if its a firmware problem ?
    from what i can figure out the voltages seem to be ok . i can check any again if needed .
    what it does as soon as its plugged in is the standby light flashes then the backlights come on then it flashes some more and goes out . backlights stay on for a minute or so then go off .sometimes it goes through this 2 or 3 times on its own .all the while backlights are off there is a very quiet click sound from the speakers like its tripping . there is no response using the remote or pressing rear toggle switch/button
    here are some pics .
  • vinceroger69
    • Mar 2012
    • 6714
    Re: digihome ptdr24hds3 backlight only no picture
    digihome are quite good they have sent me the firmware in the past for a few sets
    • petehall347
      • Jan 2015
      • 4439
      • United Kingdom
      i will look them up and ask them
      edit ..
      just looked and digihome seems to be just a name and the sets are made by vestel .did you mean i can get firmware from vestel ?
      • vinceroger69
        • Mar 2012
        • 6714
        sorry i just looked through my old emails it was http://www.umc-uk.co.uk/feedbackform.php who helped me not digihome maybe post in the fimware needed thread as some members seem too be able too help with vestel sets
        • petehall347
          • Jan 2015
          • 4439
          • United Kingdom
          i found this but cant figure out where to download the 2 files . https://translate.google.co.uk/trans...search&pto=aue
          17MB211 17MB211S Full Software Installation Method:
          the shredder_usb_update.b
          shredder_usb_update.sc is
          Copy the named files into the empty and formatted FAT32 USB stick.
          Plug the USB memory into the TV's USB-1 port and while holding down the “ OK ” button of the remote control, plug the ac cable into the wall socket and hold it until the standby led starts to flash quickly.
          Release the “ OK ” button when the standby led starts to flash quickly . When the standby led lights up, software installation process is completed.
          As a result of this process, do not install " FULL " software with different serial numbers on the TV since the panel information will change !
          • petehall347
            • Jan 2015
            • 4439
            • United Kingdom
            i am wondering about the 12v supply as its at 11.3v . would this cause the problem ?
            • diif
              • Feb 2014
              • 6978
              • England
              Just above the comments there are 5 links, Vestel, Toshiba, Telefunken, Hitachi and JVC, they go to google drives, they won't work from the translate page, you have to go from the original.
              • petehall347
                • Jan 2015
                • 4439
                • United Kingdom
                yes i already have the core file . as i see it i need the other 2 files
                unless i am being a bit thick here .?
                • petehall347
                  • Jan 2015
                  • 4439
                  • United Kingdom
                  well then ..just talked to the owner again and now he tells me the tv worked fine for 2 days after he had used the lightning/hdmi converter then one day wouldn't power on ..and he runs it off a modified sine wave power inverter . but had been fine for months .
                  he had it in his head it must be the hdmi converter that damaged it ..i dont think so myself .
                  • petehall347
                    • Jan 2015
                    • 4439
                    • United Kingdom
                    righto i might have time to look at this again .if anyone sees this post i would like to know the test points to start with . i find it hard when the schematics are not in one .
                    • raileanu
                      • Sep 2015
                      • 127
                      • United Kingdom
                      Please can someone point me from where to download the full software installation as on the link above, even if original and no translated, I cannot find any link to download the full software.
                      Many thanks in advance.
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • Ierwin
                        by Ierwin
                        05-13-2025, 03:31 PM
                      • groomit
                        Philips 50PUS7363/12 Backlight but no picture
                        by groomit
                        I'm having trouble with above mentioned TV. Bought it defect.
                        Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
                        Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
                        I can see backlight, but screen stays black.
                        What I've tried:
                        - Disconnect right side cable from T-Con -> same (backlight but no pic)
                        - Disconnect left side...
                        11-22-2024, 02:43 PM
                      • Gjackson
                        50PUS7555/12 Backlight no picture
                        by Gjackson
                        bit of a weird one today,
                        Got this set with just backlight no picture, sound etc.. works fine so mainboard and PSU are likely good. I think it's a bad panel but don't know if it's fixable, here's why:
                        T-CON voltages all present when both LCD ribbons are disconnected but if both are connected then most of the rails are gone (ex. VGH, VGL, HVDD)
                        If only one of the ribbons is connected, I do get a hazy picture from the respective side but there is a loud hum coming from the T-CON board due to what I suspect is overcurrent and the circuitry that generates...
                        11-04-2024, 02:48 PM
