Philips 47PFL4606 No Power Fuse Keeps Blowing
    replied
    Re: Philips 47PFL4606 No Power Fuse Keeps Blowing
    Originally posted by trunks81
    Hello
    Tested the two boards across. and came to the next result
    Color green is for working board and red for the not working
    All is tested without the 1K resistor
    IC905
    1= 2.85V 1.30V
    2= 1.3V 1.26V
    3= 5.92V 5.5V
    4= 0V 0V
    5= 317V 315V
    IC907
    1-2 = 1.10V 0.31V
    3-4 = 2.21V 4.80V
    C946 = 8.16V 0.70V
    D916 = 8.22V 0.70V
    What Voltage do you have on pin 3 and pin 4 of IC907 with ref to negative leg of C946?
  • dick_barton
    replied
    Those readings as in all the readings given today do not show any obvious fault.
    I have to bow out at this point since with all the checks made the fault has still not been found.
    Perhaps others can spot something I've mssed.
  • trunks81
    replied
    IC905 was an new unit.. which came from ebay, So probably from china ?
    https://www.ebay.com/itm/3pcs-T0P264...53.m2749.l2649
    When i measure R959 on both boards iam getting on one side 5.11ohm and the other side 0.15ohm
    Ordered the TOP264 at farnell (Sinuss) now and ill see if that fix the problem
    EDit used the top264 form the working board and no difference
  • dick_barton
    replied
    Other than changing IC905 once more I can't see what else there is to check.
    You have definately checked R959 and replaced D907 with a 9.1V zener diode.
    One side of R959 to hot ground should measure 4.7 ohms (plus winding resistance) and the other side of R959 should measure just the winding resistance. This will eliminate the transformer winding as a problem.
    Was IC905 replacement a new device, Chinese purchase or from a donar board?
  • trunks81
    replied
    Got the next
    IC905 to hot ground both boards measure almost the same
    1 = 9.595k 1 = 9.677k
    2 = 10.346k 2 = 10.416k
    3 = 6.620k 3 = 6.744k
    4 = 0.11ohm 4 = 0.10ohm
    5 = 2.7271k 5 = 2.7436k
  • dick_barton
    replied
    The voltages for IC905 are not too dissimilar to your test board. They will be for the Opt since there is no 5V on the secondary.
    Check the solder joints on IC905 since I feel that this is where the fault lies.
    Can you measure the resistance to hot ground of all the pins of IC905 between the good/bad board, power off.
  • trunks81
    replied
    Originally posted by dick_barton
    IC905 Pin2 is 13V or 1.3V for the working board???
    Looking through threads on this power supply and the problem tends to be either IC905 or ZD907.
    Sorry Typo its is 1.3V
    Changed IC905 and ZD907 and still the same results
  • dick_barton
    replied
  • trunks81
    replied
    Hello
    IC905
    1= 2.85V 1.30V
    2= 1.3V 1.26V
    3= 5.92V 5.5V
    4= 0V 0V
    5= 317V 315V
    IC907
    1-2 = 1.10V 0.31V
    3-4 = 2.21V 4.80V
    C946 = 8.16V 0.70V
    D916 = 8.22V 0.70V
  • dick_barton
    replied
    If you have twp identical boards, one working and one not working perhaps you could give the voltage readings of each around IC905, IC907 & C946/D146 junction.
    Also can you use your meter set to ohms to compare resistance readings against each other at the above points.
  • trunks81
    replied
    On that board i have 8,1V on C946,
    also
    The voltage on pin 3 rises to 5.9V of TOP264 !
    No difference when 1k resistor in place
    replied
    Where is the link to show me the power supply board of the 37"?
    This one, correct?
    https://www.badcaps.net/forum/showthread.php?t=85509
    That 37" board is still not fixed, correct?
    That 37" board standby power supply is working, correct? So what Voltage do you have on C946 (no need to use resistor to turn on the power supply), just power up the board by itself.
  • trunks81
    replied
    Hello
    I have two 47 inch and one 37 inch, The fixed 47 inch is gone now,
    And the 37inch board is almost exact the same as the 47 inch except for the CCFL part
    So i did compare it with that board. Also the 47inch tv starts with the 37inch board only no BL
    replied
    Hello
    C946 = still reads 0.75V,
    T904 = Measured along with the 37inch board and reads the same!
    R953 = 100 ohm
    C952 = 100.2 nf
    R956 ,R954 ,R957 ,Q908 ,R952 = Compared them with an other board and they both read the same
    37"?
    We worked on the 47" same model on this Thread: https://www.badcaps.net/forum/showthread.php?t=85971
  • trunks81
    replied
    Hello
    R953 = 100 ohm
    C952 = 100.2 nf
    replied
    "When i measure the 5V its only 2.7V, When i connect an 1K to S/B-5V iam getting 1.9V on the 5V"
    I am confused as to why you are getting Voltage on the cold side of the 5VSTBY power supply but you report this in post #21 "1. On C946 i get 0.7V ?! seems low to me !". C946 which is the filter cap for the rectifier D916 which rectifies the AC from the AUX winding of the STBY transformer T904, having 0.7V on that filter cap means the transformer AUX winding is bad or R959 (4R7 Ohms) is open. The Voltage on that C946 should be around 15V (see your thread of the same TV on another thread) when PS-ON is present, and lower when PS-ON is not present. If you look at the other thread, you will see that you will have around 4.6V output on the 5VSTBY pin, then it will jump up to 5V when PS-ON is present.
    The 15V ON C946 is used for runninng the SMPS ic's and PFC IC
    BTW, post 22 by dick_barton
    "Those results don't seem right. C946 is connected to the Opto isolator (IC907) which has 4.7V across it. It can only get that voltage from D916/C916 which you say is at 0.7V"
    I think he means C946.
    Bottom line, you need to check the Voltage on C946 again.
  • dick_barton
    replied
    So at switch on it rises to 5.5V and stays at that voltage?
    The data sheet says the initial operating voltage needs to reach 5.8V on the Control pin before the mosfet kicks in and drive the transformer so long as the Control voltage doesn't drop below 4.8.V
  • trunks81
    replied
    The voltage on pin 3 rises to 5.5V of TOP264 !
  • dick_barton
    replied
    The voltage on Pin 3 (Control) of the TOP264 should rise to 5.8V. The capacitor connected to this pin is charged up by the voltage on pin 6 (Drain). When it reaches 5.8V the internal circuit providing the charging current from the Drain supply to the capacitor switches off and the voltage across the capacitor connected to Pin 3 is then maintained by the feedback winding of T904
    Can you check that the voltage on Pin 3 rises to 5.8V
  • trunks81
    replied
    The voltage across D916 is 0.7v and C916 0.3V
  • Dannyx
    UC3842 Power Adapter Blowing Fuse
    by Dannyx
    Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
    Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
    12-05-2023, 12:06 PM
  • Tips
    Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
    by Tips
    Looking for some assistance please.
    Trying to repair a PD27AOQ samsung power board.
    Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
    Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
    Testing it the fuse blows immediately power is turned on.
    diodes dm852 and dm853 test as shorted when in the board but fine when removed.
    any assistance, guidance would be appreciated.
    04-11-2024, 11:24 AM
  • RogerH58
    Samsung 46" TV LE46B530 blowing fuse
    by RogerH58
    I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
    I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
    I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
    06-10-2023, 10:27 AM
  • corrize
    A funny fuse story – Lumix LX100 II
    by corrize
    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
    10-19-2023, 09:58 AM
  • simwalsh
    Philips 47PFL4606 Powers on, works normal then powers off after a minute
    by simwalsh
    I am new to this forum and have searched for some answers with problems similar to mine.
    Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
    It sounds like a power supply issue?
    I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
    12-04-2023, 04:03 AM
