Projector Epson EH-TW570 not Warming Up
  • bermo96
    • Jan 2019
    • 45
    • Belgique
    Re: Projector Epson EH-TW570 not Warming Up
    Originally posted by Diah
    okay our thought was the boot.. so we have now when you plug it first time at wall socket power LED goes Red as standby. after pressing power the status blinking red and keep blinking..
    let trick it by make error.. to see the error section at boot will remark them and give asign or not..such..
    1- disconnect main FAN socket and try
    2-remove the lamp ( but put back the door )
    3- while its on standby.. if you press power on RC it response ? in case yes.. then press freez keep pressing and power it on from the panel switch.. same do it by pressing the menu on RC
    So the voltages from the power supply to the ballast are :
    4,2 V
    17 V
    380 V
    I unplugged the fans one after another but nothing different happened. I have the same LED status light blinking. I have also the same behaviour when I remove the lamp.
    I have notice that 3 IC's are getting really hot when the projector is powered on. They are labelled E06210POA but I can't find any info or datasheet.
    • Diah
      • Feb 2013
      • 6386
      4,2 V
      17 V
      380 V
      disconnect all 3 LCD ribbon cable and check if the ics keep warming? and the status led behavior same or changed
      BTW you have on MB SW700 for RST
      • bermo96
        • Jan 2019
        • 45
        • Belgique
        No luck with the RST with SW700, it doesn't do anything.
        The 3 IC are still getting even with the 3 LCD ribbon cables disconnected. And the LED status has the same behaviour.
        • Diah
          • Feb 2013
          • 6386
          then its not boot i think now.. go back to service manual and check the INPUT signal switcher IC. i faced at Benq before and it was no boot i found out HDMI IC was shorted.
          • bermo96
            • Jan 2019
            • 45
            • Belgique
            The service manual doesn't provide much info but I'll try to find it. Thank you for your help !
            • bermo96
              • Jan 2019
              • 45
              • Belgique
              #26
              There was a short in the HDMI IC, a cap was shorted to ground. So I removed the IC and the short is gone but still no image and the same blinking LED status. Do you think that with the HDMI IC removed the projector can't work ?
              • Diah
                • Feb 2013
                • 6386
                if its cap was shorted then why you removed the IC.. could you remark on the MB photo which cap and IC you removed !!
                • bermo96
                  • Jan 2019
                  • 45
                  • Belgique
                  #28
                  After some inspection, the cap was shorted because the IC was shorted internally. WHen I removed the IC the short was gone. The IC is a SiI9587 Port Processor.
                  • Diah
                    • Feb 2013
                    • 6386
                    with out the IC304 it should boot and hear the ring sound of boot. you need carefully check after OPEN FB such FB304 / 302
                    • hasan7755
                      • Jan 2023
                      • Cairo
                      #30
                      any Luck here??, Got the same issue with my Epson EB-S18, when first plug in power button lights blue, when press the power, indicator "status" flashing forever and no boot, No fans spinning and the main board gets a bit hot from the same aria where the mentioned ic in the previews reply from Mr bermo96, and stays blinking with or without lamp.
                      • vestaviascott
                        Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                        by vestaviascott
                        Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                        Here's what happens:
                        1) Power on
                        2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                        3) Blue status light flashes for appx 4 minutes...
                        07-29-2020, 06:08 AM
                      • platinumsteel
                        Epson VS250 Projector Lamp Not Working.
                        by platinumsteel
                        Hi guys gooday i have a Epson VS250 Projector that turns on and is also being recognized and detected by the computer when i plug the hdmi cable.The only issue the projector lamp is not working .Are these lamps repairable ? Or i should just forget repairing the lamp and just buy a replacement. Thanks...
                        04-09-2023, 04:03 PM
                      • narf
                        Epson EB-U42 projector / Caps with 0.7 ohms ?!
                        by narf
                        hi all,
                        first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                        i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                        what i've found so far:
                        - the PSU does its job and supplies 12V to the mainboard via the connector.
                        - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                        - not far away, there's the first cap with a resistance of 0.7 ohms....
                        07-02-2024, 03:53 PM
                      • magnetepazzo
                        epson emp-x52 projector lamp temp fail
                        by magnetepazzo
                        Hi Guys i have this projector emp-x52 when power on the fan spin and lamp go on but after few seconds lamp go off and led temp flashing with fan at maximum speed. I have check the 2 termal temp but are good are 12.51 Kohm. Have suggestion for me ? TKS
                        04-23-2021, 03:37 AM
                      • EVAN STUARTS
                        Epson eb-e 01 projector
                        by EVAN STUARTS
                        Hallo guys I need some help with this Epson projector I turn it on but it stops at power light it does not switch on
                        Pliz help guyz
                        04-25-2023, 09:46 AM
