epson emp-x52 projector lamp temp fail
  • magnetepazzo
    • Feb 2017
    • 85
    • italy
    Hi Guys i have this projector emp-x52 when power on the fan spin and lamp go on but after few seconds lamp go off and led temp flashing with fan at maximum speed. I have check the 2 termal temp but are good are 12.51 Kohm. Have suggestion for me ? TKS
  • Diah
    • Feb 2013
    • 6498
    Re: epson emp-x52 projector lamp temp fail
    remove the air filter to let more air flew go inside, if the issue remain....
    it sound you have flickering at LAMP when its on high mode. inspect the high voltage socket and clean it to be sure the contact 100%. other wise the lamp will explode.
    • vestaviascott
      Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
      by vestaviascott
      Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
      Here's what happens:
      1) Power on
      2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
      3) Blue status light flashes for appx 4 minutes...
      07-29-2020, 06:08 AM
    • platinumsteel
      Epson VS250 Projector Lamp Not Working.
      by platinumsteel
      Hi guys gooday i have a Epson VS250 Projector that turns on and is also being recognized and detected by the computer when i plug the hdmi cable.The only issue the projector lamp is not working .Are these lamps repairable ? Or i should just forget repairing the lamp and just buy a replacement. Thanks...
      04-09-2023, 04:03 PM
    • hardbox
      Epson 5020UB Projector - Temp and Lamp Light Flashing
      by hardbox
      Need some idea of where to start to fix this projector. According to the user manual, when the temp and lamp lights are flashing there is an internal problem which doesn't give me much to work with. Need some input. The fans run for like two seconds when attempting to turn on then goes straight to the error code. Since it's not a lamp, fan or temp error, I'm leaning towards the power supply.
      https://www.manualslib.com/manual/74...page=80#manual
      06-24-2019, 12:56 PM
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • narf
      Epson EB-U42 projector / Caps with 0.7 ohms ?!
      by narf
      hi all,
      first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
      i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
      what i've found so far:
      - the PSU does its job and supplies 12V to the mainboard via the connector.
      - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
      - not far away, there's the first cap with a resistance of 0.7 ohms....
      07-02-2024, 03:53 PM
