panasonic tx-55fx555b firmware crashed
  • l3emarsh
    • Jul 2020
    • 28
    • england
    I have a Panasonic tx-55fx555b 4K hdr smart tv which has decided to freeze, its now stuck in standby and keeps trying to turn itself on which dont work whilst the red light is flashing constantly, all the time.
    I think whilst watching Iplayer its tried to do an update then switch itself off and on which its done in the past if it ever freezes but this time it has messed up the firmware and cant reset and reboot now.
    My question to you is have you got a copy of the right firmware for this tv as I have serched everywhere and cant find the right one, its got a vestel 17mb130s main board inside.
    I tried to do an update on the usb drive with update
    p183_3108_m22 but it just come up saying software update error on screen and goes back to not working.
    Please any advise you could give me I would be very greatfull as ive only had it 15 months and did'nt take out the extended warrenty like a fool, mainly as im out of work have been for a while due to health, hense trying to fix it myself...
    Please get back to me if you think of anything that may help me out!
  • l3emarsh
    • Jul 2020
    • 28
    • england
    Re: panasonic tx-55fx555b firmware crashed(firmware needed!)
    • Diah
      • Feb 2013
      • 6556
      upload here high resolution photo of yours Main boards showing all sticker on it
      • l3emarsh
        • Jul 2020
        • 28
        • england
        I have attached photo's of both boards and stickers as requested.
        • l3emarsh
          • Jul 2020
          • 28
          • england
          ???___QUESTION___???
          I SAW THIS ON FORUM AND DO YOU THINK IT WILL RESET MY BOARD SO IT BOOTS UP AND WORK'S AGAIN?
          Reseting NVRAM (EEPROM)
          For resetting TV, settings, you needed to remove SoC EEPROM device from TV. But it's not required. In electronic world, if you disable communication of the chip, it counts as removed. So we just needed to kill communication of SoC EEPROM. EEPROMs on Samsung TV's communicating via common i2c protocol. That protocol carries data via SDA line and send clocks via SCL line. In our situation, both blocking SCL or SDA will works. But I decide SDA.
          To do this, all you have to do that feeding (connecting) GND (ground) or VCC (3.3v) to SDA line with little wire... That's all. Since this lines are HIGH (v3.3) in IDLE, its better to hold it via VCC. You can also hold this lines via GND too. But don't try to connect both GND and VCC. It will be short circuit and probably will damage your board.
          Join VCC and SDA, power on TV and hold about for 20 seconds with the TV powered. It just try to read (wrong) settings from EEPROM, since it cannot read anything (refer to the warning message bellow), just start with defaults. That is what we want. Than releasing SDA line and shutting TV off will update the settings on EEPROM with null values, that TV could boot with it. After all, you can enter service menu and change the required changes.
            • 12328
            • U.S.
            Not sure if it will work on a panny but if you can find those pins on your board, give it a go.
            • Diah
              • Feb 2013
              • 6556
              don't play with NVRAM at all, just use V5 recovery Firmware the last links i gave you before, and use the methods i described for you too
                • 12328
                • U.S.
                So where is it diah? some other thread or what?? It's definitely not in this thread.
                • Diah
                  • Feb 2013
                  • 6556
                  before he start threat over here he contact me with e,mail and i did answer him.. all links belong to other properties forum which not allowed to share over other platform.. that is.
                    • 12328
                    • U.S.
                    Ok, mystery solved.
                    • l3emarsh
                      • Jul 2020
                      • 28
                      • england
                      Diah, Obviously I am very greatfull for your help but i have tried a couple of them files and I keep getting the same message on screen in a blue box "Software download error".
                      When using the USB Flash drive formated to Fat32 then putting the firmware file on.....
                      The file is only 1 single file but all the advise I keep reading on line say's about 3 File's that should be on the flash drive when attempting the flash/update of the Firmware, ie; an MBoot file aswell as the firmware file and one other???
                      Am I wrong or do I need other file's aswell as the Firmware file???
                      • Diah
                        • Feb 2013
                        • 6556
                        Arıza Notları gave you link to download 3 files did you tried them ?
                        • l3emarsh
                          • Jul 2020
                          • 28
                          • england
                          Diah... Well good and bad news... 1st the good= the files did load and the tv turned on!
                          2nd the bad= the firmware was for a Finlux tv and now the remolt will not work and the control button on the tv wont work either which means I am now stuck at the first screen where the language is selected for the tv.
                          I have tried to change only the firmware file on the usb flash drive and re do it but as the remolt will not work it just goes to the language screen.
                          Even though I am greatfull that you have got me half way there and confirmed that the tv is not broken and it's just a firmware issue I am still stuck with a tv that won't work.
                          I am thinking that I need a universal remolt control programed for a finlux tv to sort this out? Any advise???
                          • Diah
                            • Feb 2013
                            • 6556
                            2nd the bad= the firmware was for a Finlux tv and now the remolt will not work and the control....Any advise???
                            easy way use mouse usb or air mouse to control the tv direct..
                            or use remote apk for android on any device mobile had IR sender such Galaxy S5
                            • l3emarsh
                              • Jul 2020
                              • 28
                              • england
                              I want to thank you for all your help...
                              Even though the firmware was for a finlux tv now I have a all for one remolt I have set up the tv and it is working fine and I like the finlux set up better than the panasonic one as there is more options for app's etc.. so even though I have the latest SEC. file update from the panasonic site I don't think I am going to use it... I am enjoying the TV as it is as a Finlux!
                              A BIG THANK YOU TO YOUSELF "DIAH" YOU SOLVED IT FOR ME SO THANK YOU VERY MUCH......... THANKS!!!
                              Thank's Diah.
                              • Abkash
                                • Oct 2019
                                • Ghana
                                Please sir I have this panasonic tv TX-55ASW804 hung on panasonic logo and I need help on this tv , thank you
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4535
                                  • Italy - Milan
                                  open up a new thread, don't rob other's one..
                                  • TheUser
                                    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                    by TheUser
                                    Hello to everyone ,
                                    This is my first post here, and i would like to share with you a small story in case you can help me.
                                    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                    02-10-2024, 02:07 PM
                                  • rumpumpel1
                                    ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
                                    by rumpumpel1
                                    Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
                                    10-24-2024, 08:59 AM
                                  • dkneyle
                                    Sony KDL-46HX850 Can't upgrade/update firmware
                                    by dkneyle
                                    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                    09-25-2024, 10:44 PM
                                  • piernov
                                    Infineon TPM firmware update files
                                    by piernov
                                    Infineon TPM firmware update files:
                                    Infineon_firmware_update.zip
                                    Code:
                                    TPM12_4.32.879.0_to_TPM12_4.34.1010.2.BIN
                                    TPM12_4.33.949.0_to_TPM12_4.34.1010.2.BIN
                                    TPM12_4.40.119.0_to_TPM12_4.43.257.0.BIN
                                    TPM12_4.40.119.0_to_TPM12_4.43.258.0.BIN
                                    TPM12_4.40.119.0_to_TPM12_4.43.259.0.BIN
                                    TPM12_4.40.119.0_to_TPM20_5.62.3126.0.BIN
                                    TPM12_4.40.119.0_to_TPM20_5.63.3144.0.BIN
                                    TPM12_4.40.119.0_to_TPM20_5.63.3353.0.BIN
                                    TPM12_4.42.132.0_to_TPM12_4.43.257.0.BIN
                                    TPM12_4.42.132.0_to_TPM12_4.43.258.0.BIN
                                    TPM12_4.42.132.0_to_TPM12_4.43.259.0.BIN
                                    10-25-2025, 10:09 AM
                                  • pp74
                                    Marantz NR1508 USB firmware update image
                                    by pp74
                                    Does anyone happen to have the latest firmware for the NR1508? Marantz took their update server down and customer support refuses to provide the image to flash over USB.
                                    Regards
                                    05-10-2025, 11:55 PM
