Samsung LE40A558P3FXXU Colored lines
  • 24mech
    Badcaps Baby
    • Feb 2014
    • 103
    • United Kingdom
    Good evening, I'm looking for some help with my daughters TV please, it has recently developed an issue, When you turn on the unit you get colored lines running top to bottom of the screen, I have carried out some very basic investigation and googling from what I can gather this may be an issue with the T-con, I have check and re seated all the cables running from the av to the t con and the t con to the panel I read about several people have this issue with other models of Samsung and a temp fix by flexing the pcb av or t con until the lines clear,this I have tried with out success, before I go any further I thought I would as for some guidance from you guys.
    Thank you
  • Diah
    • Feb 2013
    • 6425
    Re: Samsung LE40A558P3FXXU Colored lines
    could you show us the issue with pictures or movie.?
    did you tried to feed the set with different source of signal such HDMI or playing video material with USB to see if the issue remain? also did you tried to reset the firmware of the TV?
    also if you disconnect one side ribbon cable between T-CON and panel.. did you got clear white color on half side panel or the lines remain??
    • 24mech
      Badcaps Baby
      • Feb 2014
      • 103
      • United Kingdom
      Thanks for the response
      this is the issue
      This it the T-con
      and this is the TV ID Plate
      I have a video, not sure how to add it though.
      • 24mech
        Badcaps Baby
        • Feb 2014
        • 103
        • United Kingdom
        that is with no feed, how do i reset the firmware are you able to point me to or provide some instructions on how to thanks.
        • Diah
          • Feb 2013
          • 6425
          forget about firmware or feeding another source.. just do test disconect one side of ribbon i mentioned before and tell the result
          • 24mech
            Badcaps Baby
            • Feb 2014
            • 103
            • United Kingdom
            This is with right (looking from screen side) cable removed
            and this is with left cable removed
            • trunks81
              • May 2020
              • 265
              • Nederland
              You should check the COF cables, probably a loose contant if not there is an short on the cof
              • Diah
                • Feb 2013
                • 6425
                however this test of ribbon removing sgould be done with signal feed cable or sat or areal.. to see the next half how the picture look.. you can do it again with signal..
                i am aware the daughter did clean the screen with spray or wet cloth which some of liquid drops down on the panel PCB boards and make damage to one or more small SMT ceramic caps.. or as usual most time we find these caps got shorted with out any liquid damage too..
                so do the test again with signal.. if same result go to inspect the 2 panel PCB or post clear photo of both side over here... good luck
                • 24mech
                  Badcaps Baby
                  • Feb 2014
                  • 103
                  • United Kingdom
                  I'm not aware of any cleaning, retest with signal feed = same result. what are you referring to by 2 panel PCB? I shall post some pictures of the T-con and av boards now, I can not see any obvious signs of component failure though you might see something I can not, thank you for assisting me with this.
                  • 24mech
                    Badcaps Baby
                    • Feb 2014
                    • 103
                    • United Kingdom
                    I did find some debris on the t-con connector cleaning it made no difference
                    Is the stain on that component normal?
                    T-con Front
                    T-con Back
                    I'll post pictures of the AV board shortly just got to take them first.
                    • Diah
                      • Feb 2013
                      • 6425
                      2 Ribbon cable which going out from T-CON to the Panel, they are connected on PCB boards of the panel.. take the metal cover of them.. you will see 2 boards left and right... here are the issue..
                        Example of Tab bonding board that you need to get to them to inspect them.
                        • 24mech
                          Badcaps Baby
                          • Feb 2014
                          • 103
                          • United Kingdom
                          Thanks for helping what am I inspecting for please? I can't see anything can you I've added some pictures of the two tab bonding boards
                            Pictures are too low res for me to zoom in to see anything in details.
                            • 24mech
                              Badcaps Baby
                              • Feb 2014
                              • 103
                              • United Kingdom
                              can I upload high res pictures? didn't think I could.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4432
                                • Italy - Milan
                                In theese models tcon is on the top so cleaning damage is almost impossibile, the first thing to do in theese cases is to check main voltages on tcon, much probably something's wrong, if all ok then processor need reballing.
                                #### NOTE FOR EVERY TV POSSESSOR, EVERY XX YEARS IT IS NEEDED A CHANGE OF THE CONTACT MATERIAL ON CPU AND HEAT SINK ####
                                • 24mech
                                  Badcaps Baby
                                  • Feb 2014
                                  • 103
                                  • United Kingdom
                                  Thanks for the info guys, I've had another look at the t-con I can see a gold circle labeled 12VIN i'm assuming this is the 12 input, what should I be using as the negative for test this feed also should I be looking for any other input voltages or outputs? thanks
                                    • 12241
                                    • U.S.
                                    Metal chassis back for ground.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4432
                                      • Italy - Milan
                                      must know the tcon model code, to find better pictures..
                                      • 24mech
                                        Badcaps Baby
                                        • Feb 2014
                                        • 103
                                        • United Kingdom
                                        On the T-con is T400HW01 V4 CTRL BD and 40T02-C02 I've added some hi res photos does this help?
                                        I'll do the 12V check today and report what I find thanks.
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                          09-07-2024, 05:50 AM
                                        • Nairolf
                                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                          by Nairolf
                                          I have a Samsung DM32D display.
                                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                          Here’s what I have tried so far:
                                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                          08-24-2025, 03:47 AM
                                        • vincentedel
                                          Samsung SyncMaster 740n Phase Control Issue
                                          by vincentedel
                                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                          04-22-2025, 12:33 AM
                                        • Manucsl
                                          QE65Q800TATXXC Samsung TV Issue
                                          by Manucsl
                                          Hello.
                                          My TV is a QE65Q800TATXXC Samsung TV.
                                          Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                          Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                          Any ideas to check would be very appreciated 😊
                                          After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                          02-19-2025, 07:47 AM
