42PFL7406 No Power
  • trunks81
    • May 2020
    • 265
    • Nederland
    Re: 42PFL7406 No Power
    Hello
    this are the part numbers of those parts
    Q601 = K3530
    Q801 = Cannot read
    Q701A = K4A60DA
    Q701B = K4A60DA
    IC601 = 2QS02G
    IC801 = 1608B
    IC701 = DDA009
    IC901 = DDA010
    IC902 = S101202D
    • trunks81
      • May 2020
      • 265
      • Nederland
      Originally posted by thommyX
      IC901 is a DDA010 and IC902 is an ST9S101 / IN1M101.
      If the brown out is faulty, you have fluctuating tensions.
      LG Thomas
      Changed both IC and problem is still the same
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        What voltage do you have across C908 and also at the FB pin 2 of IC901 and are they steady
        • trunks81
          • May 2020
          • 265
          • Nederland
          On pin 2 of IC902 iam getting 0V to 0.23V
          On C908 iam getting 13v to 19v
          Also i found that ZD904 is low in diodemode 0.0029 in both directions
          When soldered out iam getting 0.69 and reverse 2,7
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            It looks like your pfc circuit is switching on when the voltage across C908 reaches 18V and then stopping when the voltage falls which would be the reason your secondary voltages are oscillating.
            It does look like a short but is it the zener or R902 since that is across ZD904. You could lift one end of ZD904 to test it or it could be a short on the IC pin to ground.
            CS is the current source pin which would have a low value resistor (R902) attached to it and hot ground.
            • trunks81
              • May 2020
              • 265
              • Nederland
              #26
              When ZD904 soldered out iam getting 3ohm in R902 also when soldered out it is 3ohm marking on the resistor is 47Y
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                #27
                47Y is 47 ohms according to http://kiloohm.info/eia96-resistor/47Y
                Are you certain it's 47Y since that seems to be a high value resistor as a source resistor.
                • trunks81
                  • May 2020
                  • 265
                  • Nederland
                  #28
                  iam confused.. according to the same site it is an 3.01 ohm
                  Please see picture in previous post for resistor
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    #29
                    I stand corrected it is 3.01 ohms.
                      I forgot about this thread, too busy with the 37" & 47" threads.
                      So at this point if you run the power supply board by itself and force it on, is the PFC boost Voltage staying on?
                      • trunks81
                        • May 2020
                        • 265
                        • Nederland
                        #31
                        I connected pin 1 and 2 on 1M95 (CN4) with an 1K Resistor
                        And on
                        C800 = 313VDC
                        C908 = 17.21VDC
                          And on
                          C800 = 313VDC
                          C908 = 17.21VDC
                          The PS-ON (STANDBY) for this Philips power supply is Active Low, so you need to Ground pin 2 (STANDBY) of CN4 to Ground pin 3, 4, 8, or 14 using 100 Ohms resistor or so to turn on the power supply.
                          • trunks81
                            • May 2020
                            • 265
                            • Nederland
                            #33
                            does it really need to be an 100ohm ? because i dont have it right now
                            When stubborn using an 1K iam getting
                            C800=407
                            C908=17.30
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              #34
                              What are the values of R959 & R960.
                              For standby: - do you have a couple of resistors you could put in parallel. e.g. 2 x 1K in parallel = 500 ohms
                              • trunks81
                                • May 2020
                                • 265
                                • Nederland
                                #35
                                Both resistor measure oke, measured them in circuit
                                R959 = 01D = 100kohm
                                R960 = 69B = 5.11kohm
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  #36
                                  Looking at those values I think it's safe enough to short standby to ground.
                                    I suggest using resistor just in case OP ground the wrong pin on the connector by mistake if he jumps directly, OP can jump STANDBY pin to ground directly with no problem, I am just afraid that OP will make mistake and ground the wrong pin.
                                    • trunks81
                                      • May 2020
                                      • 265
                                      • Nederland
                                      #38
                                      ive used an 1K instead of 100ohm.. and that seems to work also
                                        So is the PFC Boosted Voltage present then?
                                        • trunks81
                                          • May 2020
                                          • 265
                                          • Nederland
                                          #40
                                          C800=407VDC
                                          C908=17.30VDC
                                          This is what iam getting with 1K present
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            09-06-2024, 05:59 AM
