TLC LE48FHDF3300Z Horizontal lines - question about T-Con
  • Davi.p
    replied
    Re: TLC LE48FHDF3300Z Horizontal lines - question about T-Con
    Now is ok. THe first and simpler attempt is to check with multimeter which contact on the connector on the right side is connected to the testpoint VSS1 and block it with a piece of adhesive tape, the second attempt is to perfect it blocking instead of VSS1 one or more of the CKV1/2/3 OR CKVB1/2/3 one at a time, but since i don't remember the difference between CKV and CKVB, i have to check, so for now let's be happy with the first attempt...
  • sansonet
    replied
    OK, tried it again... Location is near side flex cable (first two pics) and middle cable (pic #3)
  • Davi.p
    replied
    OK, as you can see from pictures many silkscreens are not visible, are there no sunny days there where to make photos whitout flash? i need the outer half of the board, near the side.
  • sansonet
    replied
    Originally posted by budwich
    what does that mean... "dropped in my barn"?
    you do need to post pictures of the entire screen when you do the "cable disconnect tests" so that the forum can see what is exactly happening to the screen.
    My friend brought this TV here and dropped it off in my barn.
  • budwich
    replied
    Originally posted by sansonet
    It was dropped in my barn, I dont have video signal source near it. I still can lines on blue screen so I not bothered to bring any player to it. I will try make pic or that board later.
    replied
    Ok, that explains it.
  • sansonet
    replied
    Its not connected, I never connected it back after making pics.
    replied
    The blue connector there looks a little off kilter, make sure it's ok and not out of alignment.
  • sansonet
    replied
    On pic 3 just reflection of chair with chrome legs that stands near it. It have no cracks. Attached pics are of one of those boards - full one and few close ups.
  • Davi.p
    replied
    OK sorry it's a little hard to follow the forum on a telephone, now i'm on PC and i can see better, your last pictures reveals that you can't fix 100% the fault, but at least you can let the big part of the lines to go away. So make a photograph of the outer part of the screen's internal pcb, the long tight one, one of the two is enough, them are almost equal. Silkscreens are to be visible.
    In photo 3 there is a curved line with backlight passign through, is it a scratch or a crack?
  • sansonet
    replied
    Originally posted by neilc6
    If you have lines from both sides, then the cutoff method probably won't work.
    On pic #5 all lines are gone, just one single line on middle remains.
  • neilc6
    replied
  • sansonet
    replied
    With one side disconnected, you should only see half a screen.
    I did, those halves on pics 4 and 5, I not made pics of full screen on those, just visible parts.
  • neilc6
    replied
    I did, it shown on pictures 4 and 5. One side clears up, just one line on middle still there. What is "tape cutoff method"?
    nomoresonys posted a youtube link for that method.
  • sansonet
    replied
    Originally posted by Davi.p
    It is too much hurt to input a video source instead of a poor all blue image?
    Anyway its 100% panel failure. The half connected screen test may not work on theese panels, if not make a photograph of the out part of the screen internal pcb, the long thin one, one is enough, them are almost equal.
  • sansonet
    replied
    You can connect one side at a time to see if one side is good. If yes, you can try the tape cutoff method on the bad side.
  • Davi.p
    replied
    replied
    https://www.youtube.com/watch?v=j7vl7-vZEL8
  • neilc6
    replied
    Horizontal lines are panel failures. You can connect one side at a time to see if one side is good. If yes, you can try the tape cutoff method on the bad side.
  • jostewcrew
    replied
    i will concede to others diagnosis since im still learning my self to pinpoint without a doubt....but for the guessing game...
    this is a panel failure i.m.o.
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • Ihandyrepair
    Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
    by Ihandyrepair
    Hi guys
    I just started fixing 4k TV few months ago. so I am still learning a lot
    I got this tv from friend complaint is ghosting or horizontal lines on image.
    never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
    then it started to show the ghosting white image.
    I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
    it has 3 thin small boards at the bottom of the...
    12-05-2022, 04:18 PM
  • ggil44
    Sony XBR-65X750D Horizontal lines bottom of screen
    by ggil44
    Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
    05-30-2023, 07:51 PM
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • noisykid
    Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
    by noisykid
    5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
    12-30-2024, 07:15 PM
