LG 47LW650S - no picture, no sound, no backlight, power ok?
  • timschuerewegen
    • Jul 2020
    • 26
    • Belgium
    I had paused my media player and when I came back after 10-20 minutes the TV screen was black but the power LED was white, so the TV was still on. At first I thought it was a problem with my media player but soon I realised that it was the TV. I really want to (try to) repair it because they don't make new 3D TVs anymore.
    Symptoms:
    - no picture
    - no sound
    - no backlight
    - can still be turned on/off, power LED works (red/white)
    Product Code
    47LW650S-ZC.AEUYLJG
    Power Board
    EAX62865401/8 EAY62169801
    Mainboard
    EBT61401005 LD12C EAX63686303(3) 101216
    I checked the voltages on the 24-pin connector between the power board and the mainboard with the TV turned on:
    Code:
    3.5V  => 3.540V
    12V  => 11.93V
    24V  => 24.32V
    PWR-ON => 3.438V
    ERROR => 0V
    PWM  => 3.203V
    DRV-ON => 0.042V
    Anything else I should check before I use my hot air rework station on the SoC?
    • 12331
    • U.S.
    Re: LG 47LW650S - no picture, no sound, no backlight, power ok?
    "DRV-ON => 0.042V" Looks like the mainbooard is not sending the proper voltage to turn the backlights on.
      • 12331
      • U.S.
      Try a simple reset, unplug tv for 5 minutes, hold power button in on tv for 30 seconds, plug tv in and try it.
      • timschuerewegen
        • Jul 2020
        • 26
        • Belgium
        That was the first thing I tried, but still no picture/sound/backlight. The fuses on the power board are good, the voltages are good and visually everything looks good. It probably needs a SoC reflow/reball but I want to be 95% sure I didn't miss anything else before I attempt a (temporary) repair with some hot air.
          • 12331
          • U.S.
          Try giving the bga a good heating with a hairdryer, see if it works if only for a bit.
          • timschuerewegen
            • Jul 2020
            • 26
            • Belgium
            The TV works again
            - added flux around the edges of the SoC and tried to get it under the chip (not sure if this was necessary or had any effect)
            - used kapton tape to protect the nearby components from the heat/air
            - used my Aoyue 850C hot air rework station with the 9mm round nozzle on heat setting 5 and airflow setting 5 for about 1-2 minutes
              • 12331
              • U.S.
              Nice job, thanks for feedback.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Bare in mind that this is often just a temporary fix so may be worth your while looking for a cheap replacement in the meantime.
                  • 12331
                  • U.S.
                  +10, might want to try a fan solution to try to keep the chip from overheating.
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • BoardHoarder
                    XBR-65X850D Backlight/Power On Help
                    by BoardHoarder
                    Currently trying to save a 65” 850D that definitely has a main board issue. Power supply has standby voltage and PS ON pin shows 3.5VDC but main has no signs of life…..no light under Sony logo and no optical port lit up. 12VDC is created by main board but no input triggers from main = no TCON 12V and no BL ON voltage present. I know about the trick of pulling the main to trigger the test pattern from the TCON but I get no backlight. If I jumper the 3.5VDC to TCON ON and BL ON, I can shine a light on the panel and see solid green, red, blue and white cycling. The 4 + backlight pins on the power...
                    02-09-2024, 11:00 PM
