N75UX17A-AU T-COn board issue?
  • RooTV
    • Apr 2020
    • 128
    would I be right in thinking this may be a tcon board issue?
    Soniq 75" N75UX17A-AU
    All I have is this picture and the guy said that he bought it yesterday but something must have happened in transit.
    Not sure if thats screen damage in the middle bottom or not?
  • jostewcrew
    • Mar 2020
    • 79
    Re: N75UX17A-AU T-COn board issue?
    looks like grouped dead pixels indicating panel damage i.m.o. (still learning though)
    • Soulzink
      Samsug washing machine. Power supply DC41-00189a board issue
      by Soulzink
      I am trying to fix a samsung washinmachine power supply main board.
      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
      The power supply board reference is the following: DC41-00189a
      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
      04-19-2025, 06:26 AM
    • Asraf Atb
      by Asraf Atb
      01-27-2025, 05:02 PM
    • Stephen
      A2991 Logic Board issue, 20volts 0 amps help!
      by Stephen
      Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
      09-10-2025, 03:16 PM
    • Stephen
      A2991 logic board issue, 20volts 0 amps help!
      by Stephen
      09-10-2025, 03:15 PM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
