Philips 40PFL9705 T-con 9 blinks
  • trunks81
    • May 2020
    • 265
    • Nederland
    Hello
    Ive got two screens of 40PFL9705 wit both bad tcons i think.
    I allready replaced Fet FDS8880 and FDS 8813NZ
    And i still getting the nine blinks,
    What could be an option is that both fets are defective again
    But iam out of options
  • thommyX
    • Apr 2016
    • 93
    Re: Philips 40PFL9705 T-con 9 blinks
    do you have a short circuit on C1222?
    Greetings Thomas
    https://forum.iwenzo.de/philips-40pf...r--t70475.html
    • trunks81
      • May 2020
      • 265
      • Nederland
      iam getting 35 ohms over that cap
      • trunks81
        • May 2020
        • 265
        • Nederland
        Replaced that cap but still an short
        • thommyX
          • Apr 2016
          • 93
          Exactly the same problem as me. I am in the link to the German forum. Problem is IC302. The BGA causes this short circuit due to contact errors. Unfortunately I have to wait for my delivery from China before I can continue. BGA must be reballed.
          Greetings Thomas
          • thommyX
            • Apr 2016
            • 93
            Oh yes, one of the FDS has a short circuit again. Check that too, because then it must also be renewed.
            Greetings Thomas
            • trunks81
              • May 2020
              • 265
              • Nederland
              do you have an link for that stencils you also ordered ?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4326
                • Italy - Milan
                Why do you changed that 2 mosfets?
                This sounds not to be correct, a missing of a signal can't build an overcurrent, furthermore them are smps converters so them are surely protected against overcurrent. The upper mosfet in the couple of the photo usually fails, i have substituted the FDS8813NZ with IRF8734PBF. Don't get them directly from Chinese market, Chinese people are like the Devil, you probably get fakes, get them from your Country's professional suppliers, and i have also substituted the surroundings electrolytics 1x220u2,5v, 1x22u20v, 1x39u10v, them marked well on my esr meter but i'm unsure of them, probably are the main cause. If it is not so then is a power surge.
                • thommyX
                  • Apr 2016
                  • 93
                  That can be with you. After removing the BGA, I saw the problem.
                  Now the short circuit is gone and the BGA is also OK. The capacitors are all OK with me. I just have to wait for my material until I can continue.
                  • trunks81
                    • May 2020
                    • 265
                    • Nederland
                    Are you going to use an template for reballing ?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4326
                      • Italy - Milan
                      But 35ohms is not a short. The 2 fets provides the Vcore supply for the 2 big BGA, if i remember it's something around 1v. I don't remember, for the FDS8813NZ does its Drain is connected to the 12V-in? IF yes the 12V can reach the BGA. The contemporary fault of the FET and the BGA makes no sense to me 'cause if the BGA goes short the SMPS circuit surely has a SC protection and it doesn't break. Here the OP must clarify if he has found SC on the FET after removing it. The common fault on theese boards is an intermittent SC on that FET that makes image to disappear and TV go into standby in error.
                      • thommyX
                        • Apr 2016
                        • 93
                        For me it will be a first. Otherwise I had someone else do the BGAs. But it is getting more and more and now I want to try it myself. I ordered various items. Also heat stencils, flux etc.
                        LG Thomas
                        • thommyX
                          • Apr 2016
                          • 93
                          I know that 35 ohms is not a short circuit, but if I now connect the Tcon without BGA, the FET will heal. I will see it when I have installed the BGAs what happens. I have to wait until then. Unfortunately there are no data sheets either.
                          LG Thomas
                          • trunks81
                            • May 2020
                            • 265
                            • Nederland
                            Which heatstencil did you order ?
                            • thommyX
                              • Apr 2016
                              • 93
                              https://de.aliexpress.com/item/18776...archweb201603_
                              • trunks81
                                • May 2020
                                • 265
                                • Nederland
                                Today ive got an used board from aliexpress,
                                First thing i noticed is an green stuff on those mosfets.
                                So cleaned it up and hooked the board in the tv now the tv starts and ambilight goes and sound is there, but still no image only backlight
                                Now the tv gives 3 blinks instead of 9
                                On this board the caps measure 50 ohms
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4326
                                  • Italy - Milan
                                  How much $?? I don't know why you are not listening to someone (me) that had repaired 4 of them.. instead thommyx i don't know how many..
                                  • petehall347
                                    • Jan 2015
                                    • 4426
                                    • United Kingdom
                                    FDS8880 needs soldering properly .
                                    • trunks81
                                      • May 2020
                                      • 265
                                      • Nederland
                                      Oke going to replace those fets again. They came from ebay so probably its from china.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4326
                                        • Italy - Milan
                                        there's no "Farnell","RS-components","Conrad" etc.. in your country? Get IRF8734PBF instead...
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • alltvrepairs
                                          Lg TCon test pins for screen test
                                          by alltvrepairs
                                          i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                          Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                          Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                          Appreciate your help....
                                          06-13-2025, 06:33 AM
