telefunken TE32182B29C10
  • tecnix
    • Nov 2014
    • 18
    • Italia
    Hi, I have this TV, which makes 3 flashes, a pause and three more flashes, everything repeats cyclically, the power card is: 17ips11 300413-r14, the card is fully functional and for safety tested on a working TV, the the main one is: 17mb82-2 where the error is surely hidden, now I ask you to help me find it, the Led strips have been checked and they are very efficient, the panel is: VES315WNDA-01_TW
  • yokoono
    • Apr 2010
    • 514
    Re: telefunken TE32182B29C10
    Install this software. It's for the stick. Do you know the procedure?
    • tecnix
      • Nov 2014
      • 18
      • Italia
      Thanks for replying, I'm not sure, I think it's like this: I unpack the file, put the file on a stick and put it on the TV, turn on the TV and leave for five minutes, unplug the plug, remove the stick and turn on the TV, if everything went well I should have the first video installation ... Right,
      • yokoono
        • Apr 2010
        • 514
        1. format a stick with FAT32 (stick max. 4Gb).
        2. put the unzipped file on the stick (upgrade_loader_nvclean.pkg)
        3. put the stick on the usb plug
        4. PRESS AND HOLD the OK key on the remote control. Remote control to the TV
        5. insert the TV into the socket (220v)
        6. The stby LED on the TV will flash slowly and then quickly. When it flashes quickly, release the OK key.
        7. wait for it to finish. It may take over 5 minutes. The TV can be restarted and then started with the first installation. Then you can remove the stick.
        • tecnix
          • Nov 2014
          • 18
          • Italia
          ok, procedure performed, the procedure starts as you can read the key but the TV returns to the three flashes, now, or the main board has some problems or the software is not compatible, I have another TV same characteristics only the panel code which is: VES315WNDS-01 and the Bar code of the main which is: 23134897 of course and always a 17MB82-2, another detail ... instead of three flashes it makes 5, if I succeed in the evening I do a test on this TV, I'll keep you up-to-date.
          • tecnix
            • Nov 2014
            • 18
            • Italia
            ok, software tested on the tv with 5 flashes, with a positive result, now I will have to check what the three flashes of the first tv correspond, help is accepted ... thanks
            • yokoono
              • Apr 2010
              • 514
              The posted software is a recovery software for all 17mb82 and 17mb82s boards regardless of the panel code. If it did not work you may have a hardware problem. I have other software but it is for writing spi memories with the programmer.
              • tecnix
                • Nov 2014
                • 18
                • Italia
                ok, thanks, as soon as I have more time I will try to replace the two IC 12 and 10
                • tecnix
                  • Nov 2014
                  • 18
                  • Italia
                  ok, thanks, as soon as I have more time I will try to replace the two IC 12 and 10, if you find the single software for the two IC 12 and 10 related to the panel VES315WNDA-01_TW, will you pass them to me? thank you
                  • yokoono
                    • Apr 2010
                    • 514
                    17MB82-2 panel VES315WNDA-01 flash U10+U12
                    • tecnix
                      • Nov 2014
                      • 18
                      • Italia
                      Thank you
                      • yokoono
                        • Apr 2010
                        • 514
                        If it does not work you can copy the software from the functional mainboard and rewrite it on the defective mainboard.
                        • tecnix
                          • Nov 2014
                          • 18
                          • Italia
                          thank you very much for your availability, I would like to buy an RT809F programmer but I have no idea how to use it, by the way if I have not misunderstood the instructions are all in English ... which unfortunately is not my strong suit .. .
                          • yokoono
                            • Apr 2010
                            • 514
                            Se sei solo un dilettante, RT è piuttosto costoso. Il programmatore CH341A è sufficiente per ciò di cui hai bisogno + adattatore SCOIC.
                            • lz2aab
                              • Mar 2020
                              • Bulgaria
                              yokoono, thank you very much!!! Great work.
                              • odie34
                                Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                by odie34
                                I am a hobbyist (not a professional) so please be gentle...
                                I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                02-18-2024, 09:11 AM
                              • cajoeg
                                Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                by cajoeg
                                Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                02-10-2025, 04:01 PM
                              • classypenguin
                                Need Dump - Telefunken D43F500M4CWI
                                by classypenguin
                                Hello, I have a Telefunken D43F500M4CWI mit Vestel 17MB181TC Board in for repair. The TV turns on, shows the multimedia panel with wrong time setting, then no signal and the remote control doesn't work either. Whether hard reset nor factory reset function without remote control. Are there a firmware or auto flash via usb available for this TV? If this is the case, I would like to get some guidance, because I don't had an Telefunken with programming in yet.
                                Thank you 😀
                                10-20-2024, 03:11 PM
                              • CraigR
                                Hp x360 15-u499nr power light flashes continuously.
                                by CraigR
                                I have an Hp x360 15-u499nr laptop with a continuous white blinking power light. The laptop does turn on. The light flashes with just the battery and if I disconnect the battery and just use the power cord it still flashes and with both connected it still does. I have updated the bios and tried a hard reset with battery unplugged and power cord unplugged and holding down the power button for 60 seconds. I can't think of what else to try.
                                09-16-2024, 06:12 PM
                              • dicky96
                                Bang & Olufsen (HP) Omen Laptop power light flashes once but no boot
                                by dicky96
                                Hi guys
                                I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
                                If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
                                If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time...
                                03-24-2023, 06:33 AM
