Need Dump - Telefunken D43F500M4CWI
  • classypenguin
    • May 2022
    • 7
    Hello, I have a Telefunken D43F500M4CWI mit Vestel 17MB181TC Board in for repair. The TV turns on, shows the multimedia panel with wrong time setting, then no signal and the remote control doesn't work either. Whether hard reset nor factory reset function without remote control. Are there a firmware or auto flash via usb available for this TV? If this is the case, I would like to get some guidance, because I don't had an Telefunken with programming in yet.
    Thank you 😀
  • Diah
    • Feb 2013
    • 6495
    Vestel MB didn't need dump... just install firmware. yours case it sound 2 option..
    1- incase RC don't work you use universal RC to control the TV and inter service menu to download SW and user profile to inspect them,,, it may some one play at them and change profile
    2- compete firmware install from scratch.... we have here users from vestel land will provide if they have one doesn't matter which version.
    or search here
    • Tommes
      Telefunken D43F287N4CWII - Vestel 17MB110S - Recovery Firmware
      by Tommes
      Hey Folks,
      I'm searching for a Full Flash Recovery Software
      for my Telefunken D43F287N4CWII
      Mainboard Vestel 17MB110S
      Panel: VES430UNDB-2D-N12
      Productcode: 10119394
      Does anyone know, where I can get it ?
      Or is it possible, to extract it from a working mainboard ?
      The Support Telefunken/Vestel GER couldn't help me.
      The Vestel TR Support didn't answer my email.
      History:
      The main problem with my Telefunken D43F287N4CWII was,
      it just goes out after a while, sometimes after a...
      01-04-2022, 09:56 AM
    • Unimatrix
      (Vestel) Telefunken XF43G511 - Thermal problem
      by Unimatrix
      I came across this forum because I need some advice about my Telefunken XF43G511 TV. It is originally a Vestel device. For some time now I have had the problem that the TV gets a black screen when the electronics are heated up. The backlight is still there and the sound still works. It's just the screen itself that goes off. When I switch off the TV and it cools down, the TV works again after a while. Could you please give me some advice on what could be causing this problem? I have also attached some photos of the electronics.
      Kind regards
      Thomas...
      11-19-2023, 08:39 AM
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • classypenguin
      TV Telefunken (Vestel) D50U660R2CW - on the tv screen but every 3-4 seconds lines appear on the screen flickering
      by classypenguin
      Hey, I got an Telefunken 4K D50U TV in for repair. Since the problem is t-con flex related, I isolated the problem to one side (right flex of the t-con). I taped the flex a bit, but i couldnt get any further. I attached the pictures of the t-con board in zoom in perspective. I would appreciate help for this TV. Please note that I came from Germany, so it is a bit difficult with the time zones. Greeting Tobi...
      08-29-2024, 03:47 PM
    • Davy no Caps
      Vestel 17MB82S EEprom dump required
      by Davy no Caps
      First time trying to fix a TV for a friend, it's a Bush DLED32165HD.
      Power Board - 17IPS11
      Mainboard - 17MBS82S
      Panel - VES315WNDB-02
      Red blinking standby light is on steady, press power button on remote and light flashes 7 times then stays steady, press power on remote again light flashes 10 times and then goes off.
      Checked all the voltages on the power board inc backlight circuit, they all read ok and are stable. Backlights tested with backlight tester and all work fine (2 strips x11LED on each).
      No picture, backlight or sound just blinking...
      06-06-2025, 03:22 PM
