telefunken TE32182B29C10
    Hi, I have this TV, which makes 3 flashes, a pause and three more flashes, everything repeats cyclically, the power card is: 17ips11 300413-r14, the card is fully functional and for safety tested on a working TV, the the main one is: 17mb82-2 where the error is surely hidden, now I ask you to help me find it, the Led strips have been checked and they are very efficient, the panel is: VES315WNDA-01_TW
    Re: telefunken TE32182B29C10
    Install this software. It's for the stick. Do you know the procedure?
      Thanks for replying, I'm not sure, I think it's like this: I unpack the file, put the file on a stick and put it on the TV, turn on the TV and leave for five minutes, unplug the plug, remove the stick and turn on the TV, if everything went well I should have the first video installation ... Right,
        1. format a stick with FAT32 (stick max. 4Gb).
        2. put the unzipped file on the stick (upgrade_loader_nvclean.pkg)
        3. put the stick on the usb plug
        4. PRESS AND HOLD the OK key on the remote control. Remote control to the TV
        5. insert the TV into the socket (220v)
        6. The stby LED on the TV will flash slowly and then quickly. When it flashes quickly, release the OK key.
        7. wait for it to finish. It may take over 5 minutes. The TV can be restarted and then started with the first installation. Then you can remove the stick.
          ok, procedure performed, the procedure starts as you can read the key but the TV returns to the three flashes, now, or the main board has some problems or the software is not compatible, I have another TV same characteristics only the panel code which is: VES315WNDS-01 and the Bar code of the main which is: 23134897 of course and always a 17MB82-2, another detail ... instead of three flashes it makes 5, if I succeed in the evening I do a test on this TV, I'll keep you up-to-date.
            ok, software tested on the tv with 5 flashes, with a positive result, now I will have to check what the three flashes of the first tv correspond, help is accepted ... thanks
              The posted software is a recovery software for all 17mb82 and 17mb82s boards regardless of the panel code. If it did not work you may have a hardware problem. I have other software but it is for writing spi memories with the programmer.
                ok, thanks, as soon as I have more time I will try to replace the two IC 12 and 10
                  ok, thanks, as soon as I have more time I will try to replace the two IC 12 and 10, if you find the single software for the two IC 12 and 10 related to the panel VES315WNDA-01_TW, will you pass them to me? thank you
                    17MB82-2 panel VES315WNDA-01 flash U10+U12
                      Thank you
                        If it does not work you can copy the software from the functional mainboard and rewrite it on the defective mainboard.
                          thank you very much for your availability, I would like to buy an RT809F programmer but I have no idea how to use it, by the way if I have not misunderstood the instructions are all in English ... which unfortunately is not my strong suit .. .
                            Se sei solo un dilettante, RT è piuttosto costoso. Il programmatore CH341A è sufficiente per ciò di cui hai bisogno + adattatore SCOIC.
                              yokoono, thank you very much!!! Great work.
