bn44-00604F No Secondary Power
  • R_J
    • 9638
    Re: bn44-00604F No Secondary Power
    Originally posted by afnan
    I find that in this board the R sense is connected to ground side and if it gets short, worst that can happen is it gives B- to the pin, which is ground in this case. Thanks for explaining transformer ckt.
    Then saw the power resistor right next to the MOSFET was bad and did not show any value. Bypassed it as well considering it was providing GND to the source of MOSFET
    You don't understand, When the mosfet shorted the source resistor went OPEN. Now ALL the 300 volts will appear at the mosfet source. R101 is connected between the mosfet SOURCE and the ic OCP pin. If you think that ic's ocp input handled that, then there is no convincing you otherwise.
      • 12335
      • U.S.
      How is that IC $30, some crazy shipping costs??
      • afnan
        • Jun 2020
        • 20
        Originally posted by dick_barton
        Without the exact diagram it is difficult to say what is wrong other than the capacitor on the VCC pin should initially charge to 15V and this is supplied via the voltage at the ST pin.
        If there is no kick start voltage across the capacitor connected to the VCC pin then either there's a problem with the path supplying the voltage to the ST pin, the VCC capacitor is faulty or the IC itself is faulty.
        You mention earlier that VCC - GND = 170 ohms which does seem to be low. Have you checked the components that feed back from the transformer to VCC.
        Would be interested in what others think since it's all guesswork on my part.
        Please find attached picture of the actual ST and VCC related ckt
        • afnan
          • Jun 2020
          • 20
          I am sorry if any of my comments didn't make sense. I did not factor in what will happen once the MOSFET shorts out.That schematic was for a typical SSC3S111 working. I have attached above the actual one traced from the board. You are correct.
          • afnan
            • Jun 2020
            • 20
            Yes, shipping.
            • R_J
              • 9638
              $3.56 for 5, free shipping
              https://www.ebay.com/itm/5pcs-35111-...1&isGTR=1#shId
              • jetadm123
                • 2169
                #27
                $30! Just where exactly is it being shipped from? As R_J mentioned, this part is readily available through eBay and also aliexpress. Full part number is SSC3S111. Wouldn't hurt to also change the small startup cap tied to the VCC pin.
                • afnan
                  • Jun 2020
                  • 20
                  Thanks. Purchased.
                  • afnan
                    • Jun 2020
                    • 20
                    I was able to find 0.33 Ohm resistor. The resistor used previously was 0.30 Ohm. Would it be alright if I use this?
                    • ik3umt
                      • Aug 2020
                      • Italy
                      #30
                      I'm attempting to repair similar schematics Samsung Power Supply (BN44-00750A) , dead with fuse OK
                      15NM65M Mosfet shorted, replaced with 16N65M (looks very similar)
                      R107, R108, R113 interrupted , replaced.
                      I have replaced also 3S111 with same model (is 3S111 similar to 1S311 ??? )
                      Checked all surrounding components except capacitors...
                      Powered up, immediately blown fuse and shorted mosfet !!!
                      Any hints ?
                      • caspian
                        What Zener Diodes on a Linear Power Supply
                        by caspian
                        Dear members,
                        I have a linear variable power supply with unknown brand name that I used for voltage injection.
                        Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                        In addition, I discovered that its zener diodes are defective.
                        I can replace the burned transistors.
                        But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                        Therefore, I cannot replace the zener diodes.
                        I do not want to test the zener diodes in a test circuit to discover their model or value.
                        no schematics are available...
                        05-26-2025, 12:38 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                      • WVUfan
                        PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
                        by WVUfan
                        hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
                        08-11-2025, 01:12 PM
                        09-06-2024, 05:59 AM
