LG UF6450 half screen is black, half is blue/white
  • jskuyper
    • Jun 2020
    • 23
    I have a LG UF6450 55" TV where the right of of the screen is block, the other is either blue or white. The red light when turned on flashes two times. Can anyone recommend what boards might need to be replace?
    Re: LG UF6450 half screen is black, half is blue/white
    Please provide good clear screenshots so we can see what we are dealing with.
    • jskuyper
      • Jun 2020
      • 23
      Here you go
      • Ifixstuff9
        • Jul 2017
        • 120
        Might be a bad mainboard, I'm currenly working on a uf6400 that has almost the exact same symptoms. Can you get the TV to display any video on the 'black' half?
        • jskuyper
          • Jun 2020
          • 23
          I can't get anything to display on the black side
            What happen if you have ribbon cable between LCD panel and T-CON board connected only one at time?
            Can we see the pictures of the whole back side of the TV showing all the boards?
            • diif
              • Feb 2014
              • 6978
              • England
              That coloured line i see is just a reflection ?
              • jskuyper
                • Jun 2020
                • 23
                Here is a photo of the boards
                  The T-CON board is in the middle of the picture, you can see two flat ribbon cables to the panel, you need to to try having one of them connected one at a time to see what you see on the screen, you must be real careful when disconnect and reconnect the cables.
                  Note that the tab bonding boards are on the bottom edge of the LCD panel and they can be damaged if some one spray the glass cleaner directly on the panel and the liquid can seep on to the tab bonding boards and cause damages.
                  • jskuyper
                    • Jun 2020
                    • 23
                    When unplugging one of the ribbons to tcon the black screen switches sides. When I unplug the left ribbon, the right side is black. Unplug right side left side goes black. Is it the main board then?
                    • jskuyper
                      • Jun 2020
                      • 23
                      Would anyone know of a place where this main board would be in stock? Can't seem to find it anywhere?
                        • 12085
                        • U.S.
                        What are the eleven letters on the top right of the barcode sticker on mainboard?
                          I would check Voltages on the T-CON board next.
                          • jskuyper
                            • Jun 2020
                            • 23
                            Here is picture off main board. Are these the codes you were looking for?
                              • 12085
                              • U.S.
                              Looks like there's a couple different mainboards, your part number is EBT64048902, your full model number is 55UF6450-UA AUSYLJR, DO NOT get EBT64049103 model number 65UF6450-UA BUSYLJR, I don't think it would be a direct match, like EBT64048902 would be.
                                So you are not going to do any Voltages testing on the T-CON board?
                                • jskuyper
                                  • Jun 2020
                                  • 23
                                  What would I put my meter to test and what would I be looking for ?
                                    Lets see good clear straight shot pictures of the whole T-CON board.
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      First I would test the fuse on the Tcon and see if you have the same voltage on either side of it. The fuse is often marked as "F1"
                                      • jskuyper
                                        • Jun 2020
                                        • 23
                                        Picture of tcon
                                        • Raulnn
                                          TD Systems K50DLG12US half black and half white screen
                                          by Raulnn
                                          good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                                          By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                                          01-20-2024, 04:49 PM
                                        • hcinne
                                          Dell G15 ryzen edition black screen 2 amber 1 white
                                          by hcinne
                                          I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                                          07-23-2024, 07:56 AM
                                        • maneatingmonkey
                                          LED LCD TV Screen Half Black, Half White - Panasonic TH-65AX800A
                                          by maneatingmonkey
                                          Any idea what could be causing the left half of the screen to be completely black and the right half completely white?
                                          No picture from any input or OSD. The audio, however, works fine. Also, the backlight changes intensity along with the input feed.
                                          I've tested the voltages on all the marked test points I could find and everything reads OK.
                                          I've tried applying both heat and pressure to the tabs connecting the panel to the buffer boards to no effect.
                                          Unplugging the white ribbon cables going into the 2 buffer boards on the black half of...
                                          02-28-2020, 07:22 PM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
                                        • Ihandyrepair
                                          sony 55X850D black screen no front white or red led light.
                                          by Ihandyrepair
                                          Hi guys
                                          strange one
                                          I have a dead Sony 55X850D
                                          when plug in, black screen, no front white or red LED, no back light no screen
                                          Voltages I get
                                          3.3v LD/power and main board
                                          reg 12V
                                          reg 19V
                                          3.3v on power on pin
                                          no Tcon on
                                          no tcon 12v
                                          no BL_on
                                          I do get BL_ERR 2.0v
                                          I tried to bypass it by ground it but still get same symptom
                                          I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                                          or is possible the chip next to...
                                          08-07-2024, 04:58 AM
