Lg led projector burnt led driver
  • Cryogen
    • Jan 2015
    • 91
    • United Kingdom
    Quick edit: forgot to add the model
    Lg PF1000u projector, please admin update the title. Thanks
    Hi everyone
    My projector died out a couple of weeks ago.
    It's not techically dead, I can turn it on and I can hear it boot it properly, can turn it off as well, the fan boots but there was no image, no led turning on at all.
    Yesterday I finally had the time (too busy at work) to disassemble it.
    I opened it up and found out that the led drive part of the board had a short and had burned out. The part is the dlpa3000d from texas instruments.
    It appears that pins 5 to 10 got a short and burned down, hence there is no power to the RGB leds.
    Do you think it is the driver itself that went bad or there is another short on the board probably?
    I have attached the dlpa3000d technical data sheet and some pictures of the led board.
  • Cryogen
    • Jan 2015
    • 91
    • United Kingdom
    Re: Lg led projector burnt led driver
    Pin 9 and 10 are low mosfet switch for led. I am starting to suspect that the short is in one or more of the 4 mosfets.
    I will have to test them.
    • Cryogen
      • Jan 2015
      • 91
      • United Kingdom
      Woah this was so helpful. Thanks guys.
      I mean, thanks me.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Have you removed the faulty IC and checked what damage may have been done to the board and tracks. The IC itself is pretty cheap around £10
        • Cryogen
          • Jan 2015
          • 91
          • United Kingdom
          yes I bought the chip but when I removed the burnt one I found out than the tracks are gone.
          I will have to check for someone who can repair burnt tracks. I don't have the tools to do so.
          Any idea?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            How bad is the damage. Post a sharp focused photo.
            • Cryogen
              • Jan 2015
              • 91
              • United Kingdom
              Hope they are clear, I can't find the macro in my phone.
              • Diah
                • Feb 2013
                • 6422
                the problem u have the area under the IC. need to take look under side which i think belong to pin 9
                pins 5,8,10 easy to jumper them
                • petehall347
                  • Jan 2015
                  • 4430
                  • United Kingdom
                  give it a good clean
                  • Cryogen
                    • Jan 2015
                    • 91
                    • United Kingdom
                    You mean like the short is on the other side of the board?
                    Edit. Wait, you mean you think the short is on any of the 3 smd capacitors beneath the led drive? Yes I thought of doing a full recap anyway.
                    • Cryogen
                      • Jan 2015
                      • 91
                      • United Kingdom
                      I will. I have plenty of alcohol but couldn't find a small brush.
                      • Cryogen
                        • Jan 2015
                        • 91
                        • United Kingdom
                        Here new pictures with board cleaned and other side of the led drive.
                        • petehall347
                          • Jan 2015
                          • 4430
                          • United Kingdom
                          getting this error for second 2 pics ...Invalid Attachment specified. If you followed a valid link, please notify the administrator
                          • Cryogen
                            • Jan 2015
                            • 91
                            • United Kingdom
                            Sorry pete I had to edit and reupload 20000 times cause I am using my wife's windows and am used to linux distros. I couldn't figure out how to save a rotated picture (I took the picture of the cleaned led drive upside down.
                            Should be fine now.
                            • Cryogen
                              • Jan 2015
                              • 91
                              • United Kingdom
                              Pin 9 is probably on c504 on the back of the board?
                              • Diah
                                • Feb 2013
                                • 6422
                                i think so too, but before you go further.. apply 12 VDC to the LEDs see if they come on and there no one shorted or open.
                                • Cryogen
                                  • Jan 2015
                                  • 91
                                  • United Kingdom
                                  How did you figure out that the leds are 12v?
                                  • Diah
                                    • Feb 2013
                                    • 6422
                                    its standard for projector till 100 LUM
                                    • Diah
                                      • Feb 2013
                                      • 6422
                                      here LEDs function on currents level... you are going to use 12 V with low currents.
                                      • Cryogen
                                        • Jan 2015
                                        • 91
                                        • United Kingdom
                                        I was going to apply 5v on the led drive board and see if something overheats.
                                        I need to know if pin 9 is the c504 thought.
                                        I don't wanna jumper and then short the chip again.
                                        I only have a 12v 3A power supply, that doesn't look like low currents.
                                        • electomech-fixer
                                          First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                                          by electomech-fixer
                                          I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                                          I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                                          09-15-2025, 01:42 AM
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
                                        • osrex
                                          LED DRIVER KEEPS DYING
                                          by osrex
                                          Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                                          i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                                          i have no datasheet at all for the LED lights, all i have is its length.
                                          long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                                          as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                                          05-05-2025, 03:36 PM
                                        • r38_
                                          Viewsonic VA1616W driver board burned
                                          by r38_
                                          Hi everyone, i connected my va1616w monitor to netbook and it burned components of the driver board in the vga port area, i think i bad connected the cable by mistake. After this the monitor power on but never receives signal from computer or any connected to vga port.
                                          I didn't find schematics of the driver board. Also i tried a universal lcd controller (mt6820-t) board with the panel but it was not supported. This is repairable or the board is dead? Thanks in advance. Images of the board:
                                          08-20-2022, 10:51 AM
                                        • Stephen
                                          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                          by Stephen
                                          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                          02-06-2025, 12:03 PM
