Re: Sony kd 43w8307c stuck in screen test mode.
bruce
upon closer inspection of that connector,that black soot mark rubs off so no damage to the connector.
No damage to the plastic that would indicate heat of any kind.
Getting 0v on the mainboard side PWRONLeave a comment:
thnx bruce.yes I think you are rightLeave a comment:
Hi guys
update on this.
replacement Cables were installed .
The indicator led then went from green alternating to yellow and the same intro music being played but NO backlights!!!
I then inserted the USB with the update.
This time the USB light blinked for a much longer time than the previously attempted update.
But then after approx one minute,the mainboard light went out.
Now the indicator led is flashing white .Leave a comment:
By looking at the middle of that connector it looked like it shorted, arced, and burnt through the white plastic release. You might have to replace the main and the cable.Leave a comment:
Originally posted by ;966807I hope this means you have the new cables ready. Depending on how bad the old ones are, you might just consider tossing them... just in case playing with them any more might take out either the tcon or main board.
yes I expect the replacements tomoro to arrive.
It must have been corrosion as I didnt see anything odd under the micro.
Tv powered on with no cables shows this cycling as well ..So most likely was the issue.
I will update once they arrive.Leave a comment:
I hope this means you have the new cables ready. Depending on how bad the old ones are, you might just consider tossing them... just in case playing with them any more might take out either the tcon or main board.Leave a comment:
yes,pressing the cntre allows the cable to slide out.
Both cables loss of connection.Leave a comment:
Looks similar to this if it is it will come out easily never force it: https://www.youtube.com/watch?v=_VB1qdpOc-ELeave a comment:
Anyone else knows how to disconnect these??Leave a comment:
big time ugly... that looks like some form of water ingression / contamination. hopefully, it can be cleaned / checked.
iirc, you press down in the middle section which causes the outer two edge points to lift a bit. Hopefully, someone will know for sure. Don't force things though as finding replacement cables can be tough.
I have already found the cables.Just need to make sure these are beyond
repair.
Yes,,I will not even touch the connector unless I know how it works.
I will wait for someone to be sure .thnx,Leave a comment:
iirc, you press down in the middle section which causes the outer two edge points to lift a bit. Hopefully, someone will know for sure. Don't force things though as finding replacement cables can be tough.Last edited by budwich; 06-08-2020, 08:37 AM.Leave a comment:
the most likely source of the problem is "invalid conditions" on the cable between the main board and the tcon. Some sets have a "test mode" whereby you can jumper certain pins at the tcon connector to cause this type of mode / display (I believe some form of ground). Anyways, this sony had the same problem and the fix was to check the cable.
https://www.badcaps.net/forum/showth...k+test+pattern
I suspect you will likely find a similar result.
I will do this and update for anyone also suffering this issue.
thnxLeave a comment:
I suspect you will likely find a similar result.Leave a comment:
Can you upload some photo of the working screen?Leave a comment:
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by YellowJacketHi friends,
TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find... -
Hi everyone.
Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a... -
by gigigiPanasonic tx-55cx802b stuck on panel test mode.
It was working normally but few days ago some of the LED reflectors fall off.
I've opened it up carefully, re-glued, while it was open switched it on to test LEDs.
Then carefully assembled back.
After plugging in to power remote does not work.
Using power button on the TV it turns on but gets itself into a panel testing mode: white, gradient, red, gradient, blue, gradient, green and so on switching between colours.
Anyone knows how to get out of this panel testing mode?
I've tried so... -
by modtoolDear colleagues,
I've entered the repair of the chromebook machines just one month ago and I've found some significant differences from the classic laptops or macbooks, so I'm searching some advices.
The owner of this chromebook gave it to me after it has been left flooded by water for almost a week, so chances of repair were not so high, the mainboard was oxidyzed in many spots but I made a nice cleaning, resoldering and component replaging work and now it is almost working.
Among other things I've cleaned many spots from oxyds, reballed CPU, EMMC, EC, replaced...05-07-2025, 06:10 AM - Loading...
