LG TVs losing settings after power off (fix ?)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. Although I haven't touched any TVs in the past year now, a friend called me up saying an acquaintance of his is having issues with their LG TV which loses its stored channels after every power-cycle. I ran into this issue twice before, so I instantly asked if it's an LG and of course it is, so this is a common issue.
    When I was faced with this for the very first time, I tried rewriting and even replacing the SPI chip, which although successful, didn't solve the issue, leading me to believe the problem is in the flash memory, so I ended up replacing the whole board and did the same with the following one, without even bothering to try anything on it. This is the third one I come across...has anyone else had this issue ? Is there anything that can be done to fix these boards in some way, or is the flash responsible, like some bad blocks or something ?....The model's not important right now, though I will post back when I get around to actually having a look at it. Cheers.
    Wattevah...
  • Billydv1@verizon.net
    Various Asus Motherboards losing bios settings
    by Billydv1@verizon.net
    Trying to track this down. 3 boards all same problem. Rampage IV Extreme, Z87 Pro, Z97 pro. All boot and function correctly but all lose bios and time settings if power is shut off. If power is maintained, sytrms boot and reboot normally. I have verified cmos battery is supplying 3v to board. 8 pin bios chip has continuity to ground but no voltage to vcc pin. I assume that's the pin that maintains the settings with power to bios chip. How do I track this down? What voltage do these bios chips require?
    11-30-2023, 10:27 AM
  • Conste
    Clevo W25CEW doesn't save Bios settings / shutdown issue
    by Conste
    Hello together,
    I have a Clevo W25CEW (Terra 1541) with some strange symptoms:
    1. I cannot save Bios settings by pressing "save settings" in the bios. By pressing "save & exit" it will save the settings.
    2. I can boot normally (UEFI installation), but when I shut the machine down and start it after a few seconds again it will show resume from hibernation and shutdown after POST, just before windows would boot. Then it will go back to factory settings and my UEFI installation will not boot!
    Already changed the CMOS battery...
    09-01-2021, 10:34 AM
  • Shpic
    DELL Inspiron 7567, Brick, BIOS restore to Factory settings issue
    by Shpic
    Hello everyone!
    I have a weird situation. I'll try to explain. I bought my laptop with Linux. After half a year I decided to install Windows 10 Pro x64 (I bought it). So, I wiped everything on my HHD drive and installed W10 without any problems. For 3 years the laptop worked well, but I decided to give it to another person. I started preparation to a new user. Firstly I restored Windows to default settings with wiping all user's data, it went well with no issues. And the last point was wrong for me, I decided to restore also BIOS (1.15.0) to factory default. After I pressed the...
    11-22-2021, 01:45 AM
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    🛠 Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • ugamazing
    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
    by ugamazing
    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
    12-17-2024, 07:05 PM
