Panasonic TC-P42ST30: Repair for 14 blink code
  • LongLiveMyPlasma
    • May 2020
    • 11
    My beloved Panasonic TC-P42ST30 has been stricken with the 14 blink code.
    I've spent many hours reading through forums, watching YouTube videos and reading the Panasonic plasma troubleshooting guide. But I'm a novice at this, and still need some help to cross the finish line.
    I understand the Panasonic troubleshooting guide suggests that the 14 blink code usually means there's a problem with either P-board or A-board. However, I also learned the problem frequently rests with the SN-board.
    Using my multi-meter, I was able to confirm the P-11 pin on the P-board is working fine, which leads me to believe the A-board is probably fine, too.
    The P-2 pin on the P-board is testing as a short. I ordered a replacement board, tested it and had the EXACT same problem with P-2 testing as a short.
    Question: Just double checking, if the P-2 tests as a short, that means the board needs to be replaced, correct?
    The SC/SN-2 pin on the SN-board is also testing short.
    Question: If the SN-2 pin tests short, that means the SN-board should be replaced, correct?
    Thank you!
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Panasonic TC-P42ST30: Repair for 14 blink code
    Check thes 4 ibgt's for a short. Leg to leg and leg to tab.
    • LongLiveMyPlasma
      • May 2020
      • 11
      Thanks for the suggestion!
      Okay, I tested the four IBGT's you identified in the photograph and they all failed.
      Question: I'm pretty sure this means the SN-board needs to be replaced, correct?I found a guy who will fix the board if I send it to him.
      Question: And in follow-up to my earlier question, if the P-2 tests as a short, that means the P-board needs to be replaced, correct? The original board and my replacement board both tested short at the P-2 pin. Coincidence or not? I'm not sure.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        The power supplies rarely fail in this model. I would have the board repaired and go from there.
        • LongLiveMyPlasma
          • May 2020
          • 11
          Okay, I'm sending my board off to get repaired and I'll check back in here to let everyone know how it worked out it. In the meantime, if anyone else has any thoughts on my P-board situation, please chime in. Thanks!
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            When you reinstall the sn board, use the new style screws with the lock washers. Shopjimmy sells them. Also, take your time re fitting the panel ribbons. If you see lines on the screen, turn the TV off and redo. I run the anti image screen with the scrolling black bar to check for any lines. You may have to reseat them alot. Good luck!
            • LongLiveMyPlasma
              • May 2020
              • 11
              Here's an update: After installing the repaired SN-board, the TV no longer gives me the 14-blink code. However, I still don't have a picture. It turns off and on with ease (before it wouldn't turn off). My best guess here is that I need to find a working p-board (the first two boards I've I ordered have been DOA). As I mentioned earlier in this thread, the P-2 pin on the p-board is testing as a short to ground. Is anyone has any ideas or suggestions, I'd like to hear there them.
              Also, could someone post a link to the ShopJimmy new style screws with lock washers recommend by the previous poster? I couldn't locate them. Thanks!
              • tvtimmy
                • Mar 2015
                • 1160
                • usa
                Do you get a short on p2 when the plug to the sn board is removed? Also is this plugged in?
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  Send a pic of the repair to your SN board.
                  • LongLiveMyPlasma
                    • May 2020
                    • 11
                    Yes, the short on P2 occurs when the plug to the SN-board is removed.
                    The part you ID'd is plugged in.
                    • LongLiveMyPlasma
                      • May 2020
                      • 11
                      I already screwed the SN-board back in and I don't want to take it out right now because it was a real pain sliding the ribbons back in. To my untrained eye, I couldn't see any obvious repairs to the top of the board. The bottom of the board, though, had some discoloration that suggested areas where repairs were made. If I need to take it out, I'll take pictures.
                      • LongLiveMyPlasma
                        • May 2020
                        • 11
                        I ordered another P-board today, so I'll do an update after it arrives. I really hopeful that's that only remaining problem. The 14-blink code is gone and the TV easily turns off and on. I just don't get a picture or sound.
                        • tvtimmy
                          • Mar 2015
                          • 1160
                          • usa
                          Here are the screws for it.
                          • LongLiveMyPlasma
                            • May 2020
                            • 11
                            What is the benefit of these screws versus the original screws?
                            And these go on the board, right?
                            • tvtimmy
                              • Mar 2015
                              • 1160
                              • usa
                              The old screws don't have lockwashers and they loosened up causing the problem. The new ones won't .
                              • LongLiveMyPlasma
                                • May 2020
                                • 11
                                My Panasonic TC-P42ST30 has been resurrected from the dead! Here's what happened:
                                Ultimately, the problem was the SN board. I found a guy in California on eBay (user name: asa.vd.pc) who charged $69.00 for the fix.
                                I am beyond thrilled that I didn't have to scrap it. Thanks to everyone on this forum who shared their success stories in other threads. It kept me motivated.
                                I did take a some costly wrong turns. The Youtube videos and Panasonic diagnostic document floating around out about the 14-blink error code all suggested that the P-board was likely the #1 problem. In my case, this was completely wrong.
                                I bought a couple of P-boards I didn't need. Luckily, I was able to return one at no cost. I think I might need to upgrade my multi-meter too because I got some contradictory readings at certain points
                                It took awhile, but it was all worth it. One important tip. Snapping the ribbons back into the SN board can be very tricky. I did it wrong the first time and got no picture at all. I tried it again and had lines all across the screen. Be careful. I was really nervous about damaging the ribbons because you have to use a bit of force to have them sit JUST RIGHT.
                                • tvtimmy
                                  • Mar 2015
                                  • 1160
                                  • usa
                                  I turn the tv on and run the scrolling bar screen cleaner feature to make sure I have zero lines across the screen.
                                  • cloo
                                    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                    by cloo
                                    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                    After doing a factory reset this problem was gone and the picture was back to...
                                    01-06-2025, 06:02 AM
                                  • Vebririon
                                    panasonic TX-P50V10E 6 blink led problem
                                    by Vebririon
                                    I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                    Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                    I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                    05-17-2025, 10:16 AM
                                  • nervx
                                    Panasonic TH-42PZ800 8-blink error mystery
                                    by nervx
                                    Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
                                    Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
                                    04-08-2022, 05:19 AM
                                  • SentraDude
                                    (Another) 7 BLINK TC-P60VT60 Panasonic - NEWBIE
                                    by SentraDude
                                    Greetings from SoCal I am new to this forum but not new to forum world. I come from Automotive end of side which is my main passion in life. Give the automotive nature, I love fixing and restoring things and I have in the past fixed many simple electronics, soldering, etc.. but this is a bit more involved so I found this forum, and I am very glad I did.
                                    I picked up a Panasonic TC-P60VT60 with the 7 BLINK error.
                                    Upon removing the back plate I found spider webs, dead spiders, and an amazing amount of dust. I did my best to clean the surface of the boards with a portable vacuum...
                                    04-04-2023, 04:24 PM
                                  • BigPete
                                    Panasonic Heatpump Dryer Repair
                                    by BigPete
                                    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                    Unfortunately the whole machine has to come apart to fix it.
                                    I have...
                                    Today, 06:40 PM
