Sharp Blinking error codes
  • Suburban91
    • May 2020
    1-5-2015 - 5/16/2020 tv worked perfectly
    5/17/20 tv turns on for 3-5 min then....fuzzy screen, vertical lines of all colors, screeching sound, screen goes black. power light blinks 3 long then 3 short.
    i have looked for hours for this blinking link sequence, can anyone point me in the right direction for decipher this code?
    Sharp Aquos
    LC_80LE632U
    serial 111820555
    120v 60hz 307w
    Re: Sharp Blinking error codes
    See service manual.
    BTW you should put make and model of the TV on the subject line, also attach good clear pictures of the whole backside of the TV showing all the boards.
    • Suburban91
      • May 2020
      Thank you so much. For some reason I could not open your file earlier but now it opens just fine.
      Main PWB. Regular communication error
      So now I guess I’m shopping for one of those things now.
      • Suburban91
        • May 2020
        Needing a little bit more help please
        I am having a big problem finding the PWB what is the difference in the FM24S (everything I see is listed for 70 inch but this is the board that I just pulled off my TV ) and the FM98S(this is listed for the 80 inch which is the size TV I have)
        • nomoresonys
          • 12206
          • U.S.
          They look pretty scarce, is that repair kit helpful? might show what to test: https://www.ebay.com/itm/Sharp-RUNTK...ss!43616!US!-1
            Are you trying to get new Main board or the power supply board?
            Did you do any Voltage testing on the power supply board?
            • michalk3777@gmail.com
              Sharp Hisense - LC-65N7004U Error codes
              by michalk3777@gmail.com
              Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
              Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
              Regards,...
              12-15-2024, 09:20 PM
            • Superbee_dad
              Sharp 80” long short flash backlight error - Help
              by Superbee_dad
              Hello Sharp TV experts
              Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
              > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
              > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
              01-24-2025, 11:51 PM
            • mecha1166
              QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
              by mecha1166
              I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
              03-28-2024, 08:31 AM
            • Sus256
              HISENSE 65E7KQ PRO - no boot
              by Sus256
              Hi all!
              HISENSE 65E7KQ PRO
              RSAG7.820.13512 - chassis
              MT9618BAATAB - cpu
              RSAG7.820.12059 - power
              HD650Y3U77 - panel
              KLM8G1GETF - emmc
              Replaced emmc.
              Terminal log
              UART
              AC_ON
              E-B
              FDE enabled
              06-01-2025, 02:11 AM
            • Yanleb
              Sharp LC-60LE810UN Lamp Error
              by Yanleb
              I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
              I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
              Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
              I've tried all the key...
              08-24-2021, 11:48 PM
